Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-434FixedWAV Audio playback slow playback/off-pitchApalis iMX6, Colibri iMX6Analog AudioWEC7, WEC2013
Description: Due to a clock misconfiguration, audio playback is 10% slower than expected and this impacts also the pitch.
Workaround: The issue has been fixed in release 1.4b4
