Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-409Fixed"UseSplashSetting" parameter default to trueApalis iMX6, Colibri iMX6Graphics, HDMI, LVDS, RGB, VGAWEC7, WEC2013
Description: Since release 1.4b4 the display driver will use splash screen settings from the bootloader by default. If this is not the desired behaviour the parameter must be explicitly set to 0 in the registry. If you currently have settings in the registry that you want to be applied by the OS you need to explicitly set UseSplashSettings to 0, otherwise bootloader settings will be used instead. Link to display registry settings description: https://developer.toradex.com/knowledge-base/display-driver-registry-settings
