Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-410New FeatureEntering recovery mode in softwareApalis iMX6, Colibri iMX6BootloaderWEC7, WEC2013
Description: Adding new bootloader command to enter recovery mode: "reboot rcm"
Workaround: Issue has been fixed in version 1.4b4, supporting "reboot rcm" command, on older releases you can use two bootloader commands:
bootfrom usb
reboot
