Search by Tags
WEC iMX7 BSP Release
Clear Filter
Not Planned
WC-885Known IssueTCP DHCP settings "Lease Expires" date is wrongColibri iMX7EthernetWEC7
Description: The "Lease Expires" date is always set to 1/1/1970 initially. This seems to be WEC7 related issue. This is not an issue on CE6.
Workaround: Do a ip renew (ipconfig /release, ipconfig /renew) to get a correct "Lease Expires" date. If you build your own Image, you can also use a legacy dhcp.dll.
