Search by Tags
WEC iMX7 BSP Release
Clear Filter
1.1b4 (Release date: 2018-03-30)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until September 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until November 2017
WC-860FixedSD Card clock was set to highColibri iMX7SDIO/SD/MMCCE6, WEC7, WEC2013
Description: Some SD Cards may not work because frequency was set higher than requested
Workaround: Use registry setting MaximumClockFrequency to limit frequency. You can find more information here -> https://developer.toradex.com/knowledge-base/colibri-i-mx7-sd-card-interface
