Search by Tags
WEC PXA BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the PXA Windows CE BSPs and images.
Clear Filter
V4.6 (Release date: 2018-03-08)
The version 4.6 contains only one change in the bootloader, see issue #34332 below for details. The change is related to initial production programming at the factory only and doesn't affect normal usage. The WinCE image and BSP were not changed and therefore not rebuilt for 4.6. They stay at 4.5. Customers can continue to use their tested bootloader and image version as the issue fixed in 4.6 bootloader isn't critical and doesn't have any affect in normal boot mode.
WC-1230FixedBadBlock detection during initial production programming takes too longColibri PXA320, Colibri PXA310, Colibri PXA300 XT, Colibri PXA300BootloaderCE5, CE6
Description: The bootloader contains code which is used during initial programming at the factory only. In this code there was a bug which could have lead to timeouts during production depending on the content of the flashes coming from the flash manufacturer. This bug was fixed in the bootloader 4.6. This change doesn't have any impact on normal boot behavior and only changed the behavior during a special test mode during initial programming at the manufacturer.
