Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0beta2 (Release date: 2016-08-23)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M06
- WEC 2013 Updates: Installed Updates until 2016M06
To Upgrade to 2.0 beta 2 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1509FixedEthernet adapter sometimes not detected after boot or connection lost during runtimeColibri T20, Colibri T30EthernetCE6, WEC7, WEC2013
Description: On some modules the Ethernet controller sometimes is not detected during the boot process or the link drops during run time. Most often this happened if there was activity on the GPIO Y0 to Y3 pins (i.e. SPI).
Workaround: Reset the Ethernet Controller By generating a low pulse on GPIO V4 (Colibri T20) or GPIO DD0 (Colibri T30).
