Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0beta2 (Release date: 2016-08-23)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M06
- WEC 2013 Updates: Installed Updates until 2016M06
To Upgrade to 2.0 beta 2 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1593FixedUpdate tool < 6.0.4 saves serial number in wrong formatColibri T20, Colibri T30, Apalis T30ConfigBlock, WinCE FeatureCE6, WEC7, WEC2013
Description: If no serial Number was found the Update Tool prompts the user to enter a number. This number was stored in a wrong order to the config block. This was fixed in Update Tool 6.0.4
Workaround: Use Update Tool 6.0.4 and later.
