Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0beta2 (Release date: 2016-08-23)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M06
- WEC 2013 Updates: Installed Updates until 2016M06
To Upgrade to 2.0 beta 2 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1562FixedFix USB identifier for USB RNDIS platform debugging with Windows 10Colibri T20, Colibri T30, Apalis T30USB, WinCE FeatureCE6, WEC7, WEC2013
Description: The RNDIS driver which is used for platform debugging is not working properly on Windows 10. The identifier will change to the following: Class 0xEF Subclass 0x04 Protocoll 0x01 For platform debugging a new RNDIS device will be installed. Make sure you update the RNDIS connector IP after upgrading to this Image / Bootloader version.
