Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0beta4 (Release date: 2017-01-04)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M10
-WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M09
- WEC 2013 Updates: Installed Updates until 2016M11
To Upgrade to 2.0 beta 4 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1444Fixed100mW power saving by changing default setting of multiplexed pins of camera inputColibri T30, Apalis T30Bootloader, GPIOCE6, WEC7, WEC2013
Description: Adapted default pin settings in order reduce power consumption. On the following GPIOs a internal pull up is set: V2, V3, CC7, DDD6 and DD5. Configuration is done in the gpio.bootconf, see also issue 7823.
