Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
2.2b4 (Release date: 2018-09-17)
- WinCE 6 Updates: Installed Updates until 2018M03
- WEC 7 Updates: Installed Updates until 2018M06
- WEC 2013 Updates: Installed Updates until 2018M07
WC-1633FixedUSB Does Not Work Anymore When Loading in Reverse OrderColibri T30USBCE6, WEC7, WEC2013
Description: USB can turn non-functional after changing USB registry values. This was now fixed and the USB instances can be loaded in any order
Workaround: Change the "order" value of [HKEY_LOCAL_MACHINE\Drivers\BuiltIn\USBEHCI1] to assure it is loaded before the other USBEHCI drivers.
