Search by Tags
Toradex CE Libraries Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex CE Libraries.
Issues which are scheduled for a specific version (e.g. V1.1) will be integrated in the mentioned version of the Libraries.
Clear Filter
2.1 (Release date: 2018-01-12)
- Added CANLib for Tegra
- Improved SPILib performance and fixed default pin mappings
- Improved I2CLib
- Improved CANLib performance
WCL-631FixedCANLib: Changed config name "FrameFormat" to "FilterFrameFormat"Colibri iMX7, Colibri iMX6, Colibri VF50, Colibri VF61, Colibri T20, Colibri T30, Apalis T30CANCE6, WEC7, WEC2013
Description: "FrameFormat" was initially used to set the frame format used for CAN_Write() calls. Since the frame format can now be set as a flag in CAN_Write it does not make sense to have this config anymore. Instead we introduced a "FilterFrameFormat" config to filter out (remove) extended (29bit) or standard (11bit) received frames.
