Search by Tags
Toradex CE Libraries Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex CE Libraries.
Issues which are scheduled for a specific version (e.g. V1.1) will be integrated in the mentioned version of the Libraries.
Clear Filter
2.4 (Release date: 2020-03-05)
WCL-600FixedI2CLib - Unlocking I2C bus after module reset does not workColibri VF50, Colibri VF61I2CCE6, WEC7, WEC2013
Description: The I2C library tries to "unlock" I2C bus if a slave device is not releasing the SDA signal, this may happen if the module is reset in the middle of an I2C transaction when the slave device has control of SDA line.
Workaround: Issue has been fixed.
