Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
Clear Filter
1.5b4 (Release date: 2017-10-19)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until June 2017
- WEC 7 Updates: Installed Microsoft WEC7 Updates until June 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until August 2017
WC-2446New FeatureChanged I2C driver to libraryColibri VF50, Colibri VF61I2CCE6, WEC7, WEC2013
Description: To use I2C it is recommended that you use latest library. We disabled I2C driver and will not support use of driver in the future.
Workaround: If you need to re-enable the driver because of backwards compatibility ( not recommended ) you can rename entry under [HKLM\Drivers\BuiltIn\I2CX] Dll=i2cdriver.dll This will re-enable the driver but new version of library will not work with this.
