Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
Clear Filter
V1.0beta7 (Release date: 2014-08-25)
WC-2499New FeatureAdd Support for USB client (device) driverColibri VF50, Colibri VF61USBCE6, WEC7, WEC2013
Description: USB Client driver is supported. ActiveSync, Storage or RNDIS drivers can be configured following the instructions of this knowledge base article: http://developer.toradex.com/knowledge-base/usb-function-driver-%28colibri%29 The USB mass-storage profile can't be used to access the internal flash from a PC because this storage is partitioned in a way that is not supported by Windows or Linux. This partitioning system is required to support wear leveling on the filesystems mounted on the internal flash.
Workaround: In order to debug applications without using USB Client, please refer to the following knowledge-base article: http://developer.toradex.com/knowledge-base/colibri-vf50-vf61-wince-bring-up#Application_debugging
