Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
Clear Filter
V1.0 (Release date: 2014-10-10)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2013M01
- WEC 7 Updates: Installed Microsoft CE7 Updates until August 2014
- WEC 2013 Updates: Installed Microsoft CE8 Updates until Update 5
WC-2582FixedDownload image to flash from platform builder does not workColibri VF50, Colibri VF61BootloaderCE6, WEC7, WEC2013
Description: Download is completed and image is started, at next boot the config block is reset to default values an "no image has been saved to flash" error is generated when launching the image. The issue has been solved in release 1.0
Workaround: In older bootloader version images could be flashed reading them from SD card only.
