Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
V1.2beta1 (Release date: 2015-07-22)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until May 2015
- WEC 7 Updates: Installed Microsoft CE7 Updates until May 2015
- WEC 2013 Updates: Installed Microsoft CE8 Updates until May 2015
WC-2526FixedFixed buffer overflow on serial portColibri VF50, Colibri VF61UARTCE6, WEC7, WEC2013
Description: Fixed issue that would create buffer overflow inside UART driver. It's still possible to get an overflow when using big packages or high data rates without using flow control!
Workaround: Please use RTS and CTS flow control if you have bigger data packages or high data bandwidth.
