Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
1.6b4 (Release date: 2018-12-21)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until March 2018
- WEC 7 Updates: Installed Microsoft WEC7 Updates until September 2018
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until October 2018
WC-2430FixedDisabling/Enabling etherent on powerup is not reliableColibri VF50, Colibri VF61EthernetCE6, WEC7, WEC2013
Description: On some modules in certain temperature ranges Ethernet might not work after suspend or after bringing down the network interface. The LED constantly blinks and receive/transmit errors might be reported. No frames can be received or sent in this state.
Workaround: If you are using suspend mode you have to disable Ethernet to improve power consumption. Delete "ImagePath" entry under HKLM\Comm\ENET to do so.
