Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
1.7b2 (Release date: 2019-12-06)
- WinCE 6 Updates: Installed until 2018M03
- WinCE 7 Updates: Installed until 2019M09
- WinCE 8 Updates: Installed until 2019M09
WC-2808FixedNAND flash blocks are marked as bad too earlyColibri VF50, Colibri VF61FlashCE6, WEC7, WEC2013
Description: A NAND flash block will be marked as bad as soon as a single bit-flip is detected. The error correction can correct up to 24 bit-flips. This can lead to early reduction of the available memory in the flash filesystem, and prevent an application from storing more data.
Workaround: The flash does not really get defective by this error. Low-level formatting and updating the OS to the latest version solves the problem.
