Version: 6
Using Multiple Containers with TorizonCore
A strong advantage of the Torizon platform is the possibility to work with microservices architecture. This software development technique provides great advantages such as modularity, scalability, integration, and distributed development. TorizonCore is the base operating system in which Torizon is built and provides Docker for microservices implementation using containers.
In this article, you will learn how to orchestrate multiple containers, for example, the ones from the List of Container Images for Torizon, and manage the inter-communication process from a sample implementation using Grafana, Collectd, and InfluxDB.
IDE Extensions (not used in this example)
Since this article explains a concept, it will not use Toradex's Extensions for Visual Studio and Visual Studio Code. Nevertheless, the concept can be applied while using them, of course. The following resources can help you configure multi containers applications using our extensions:
  • A Computer on Module with TorizonCore installed, as explained in the Quickstart Guide.
Working with Multiple Containers
Docker Compose
Compose is a tool for defining and running multi-container Docker applications. Compose uses a YAML (*.yml) file to configure the application’s services. With the Compose file, in a single command, you create and start all the services from your configuration. There are some advantages to create a docker-compose (.yml) to orchestrate the execution of your containers. These include:
  • With a docker-compose file you can have all the parameters to launch a single or multiple containers saved on a file.
  • You can provision a device (or a fleet of devices) in Torizon Platform and update its containers remotely over-the-air just by sending the YAML to the web application.
  • A developer can pre-provision his containers with a TorizonCore image, and have a single image to flash on production.
Communication Inter Containers
When executing a system with multiple containers, some methods can be applied for communication and message passing between containers. Some of these methods are files/directories sharing and IP sockets. In this example, we will show communication through IP sockets (The communication will be done through HTTP requests).
By default, Docker Compose sets up a single network for your app. Each container for a service joins the default network and is both reachable by other containers on that network, and discoverable by them at a hostname identical to the container name. For more information, please, refer to Networking in Compose page.
Example: Multi-Container Application with Grafana, Collectd, and InfluxDB
In this example, we will show a multi-container application that displays the performance data of a Toradex's Computer-on-Module (CoM) using the following open-source software: Grafana, Collectd, and InfluxDB.
Briefing
Grafana is a data query and presenting tool, which lets us build a graph chart based on InfluxDB. InfluxDB is our time-series database. Grafana sends a query to InfluxDB (port 8086) by an HTTP request.
Collectd is a Unix daemon that collects, transfers, and stores performance data of computers and network equipment and sends it to InfluxDB.
In summary, Collectd will produce data and store it in the database (controlled by InfluxDB). Grafana will consume the data in the database and display it. In this example, we want to have 1 Docker container for each of the components - Grafana, Collectd, and InfluxDB. Hence, the core of our application contains 3 containers and the main YAML (.yml) file.
It is possible to show Grafana on local video output, in addition to having it served over a network interface. To make this possible, we bring-up a Weston container and a Chromium container in kiosk mode. This is an optional part of the demo that uses 2 extra containers and an extra YAML (.yml) file. You can easily remove it if you want.
High-level Architecture - How Containers Interact Between Them and the External World
Instructions
First, obtain the files of this example. To do that, clone the repository to your PC:
$ git clone https://github.com/toradex/torizon-samples
Copy grafana directory from your PC to your module using scp (replace X.X.X.X by your module’s IP-address):
$ scp -r ./torizon-samples/grafana/ torizon@X.X.X.X:/home/torizon/
Connect to your module's shell by using SSH:
$ torizon@X.X.X.X
In your module's terminal, change the current directory to the "grafana" directory:
# cd /home/torizon/grafana
The muti-container orchestration and configuration for this example are provided in:
you are advised to consult the Compose file reference and the article Share Compose configurations between files and projects when customizing the example or writing your own.
If you want to show Grafana on a local display, copy either docker-compose.override.armhf.yml for 32-bit targets or docker-compose.override.arm64.yml for 64-bit targets, as docker-compose.override.yml.
cp docker-compose.override.arm64.yml docker-compose.override.yml
To execute the application defined by the YAML file, execute the following command. Compose automatically uses the files named docker-compose.yml and docker-compose.override.yml if no other files are specified with the -f option:
The option -d or --detach runs the containers in the background in detached mode.
# docker-compose up -d
Release Versions
Often during development, the tag latest is used for bringing up containers or basing Dockerfiles (FROM <image>:<release version>). That is OK but often one wants to set a specific version to prevent things to break due to an updated that has not yet been validated, for instance.
This demonstration uses specific versions for Grafana (grafana:<release version>) and InfluxDB (influxdb:<release version>). consult the docker-compose.yml to see what are the latest versions being used by the current example.
Example Explained
Key snippets from the docker-compose.yml are explained below:
docker-compose.yml
# version 2.4 enables the declaration of cgroup rules
# only use newer if you don't need to use cgroup rules
version: '2.4'
# Declare the containers and their configuration
services:
# You can add a node for each container. We focus on Grafana in this code snippet
grafana:
# container_name enables you to access this container using a hostname
# such as http://grafana
container_name: grafana
# declare the networks attached to the container
networks:
- backend
- frontend
# declare bind-mounts, volume and tmpfs
volumes:
- "grafana-storage:/var/lib/grafana"
# declare open ports (they must be exposed in the Dockerfile)
ports:
- "3000:3000"
links:
- influxdb
# this is the actual Docker image to be used
image: grafana/grafana:6.7.1
# declare Docker networks
networks:
backend:
internal: true
frontend:
internal: false
# declare volumes
volumes:
grafana-storage:
influxdb-grafana:
Key snippets from the docker-compose.override.arm64.yml are explained below:
# this override brings up Grafana on a local display
version: "2.4"
services:
weston:
# pass environment variables to the container
# in this example, you accept the NXP EULA with regards to use of Vivante
# binaries for GPU-accelerated graphics
environment:
- ACCEPT_FSL_EULA=1
container_name: weston
image: torizon/weston-vivante:2
# Required to get udev events from host udevd via netlink
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup rules
device_cgroup_rules:
# ... for tty0
- 'c 4:0 rmw'
# ... for tty7
- 'c 4:7 rmw'
# ... for /dev/input devices
- 'c 13:* rmw'
# ... for /dev/dri devices
- 'c 226:* rmw'
# ... for /dev/galcore device on i.MX8
- 'c 199:* rmw'
kiosk:
container_name: kiosk
# in this example, you pass the machine name to the container to help
# determine whether or not to enable GPU H/W Acceleration for chromium
# which is enabled by default for all targets except the GPU-less SoMs
# i.e. colibri-imx7-emmc and colibri-imx6ull-emmc
environment:
- MACHINE
image: torizon/chromium:2
# run a custom command, equivalent to CMD on a Dockerfile
command: --window-mode http://grafana:3000
security_opt:
- seccomp:unconfined
networks:
- frontend
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /var/run/dbus
target: /var/run/dbus
- type: bind
source: /dev/galcore
target: /dev/galcore
# only bring-up this container if others are successfully started
depends_on:
- weston
- grafana
- influxdb
# size of shared memory between containers
shm_size: '256mb'
- 'c 199:* rmw'
To know more about the device_cgroup_rules section of the docker compose file above, please refer to the Hardware Access through Control Group Rules (cgroup) section of the Torizon Best Practices Guide article
How to Use the Example - Configure Grafana
Open a browser on your computer, on the same network as the board, and access the board IP address on port 3000 http://X.X.X.X:3000/ and log in with default (user: admin, password: admin).
If you are using the optional local ui the Grafana login page will open automatically on a screen attached on the device board.
Click Add data source:
  • select InfluxDB as a data source type
  • set URL to http://influxdb:8086 (we use docker link, so we can access it by container name)
  • write the name of your database (“collectd“ in our case)
Grafana Config
  • Click Save & Test button, it should say "Data source is working."
Create a new Dashboard:
Create Dashboard Item
  • Select Choose Visualization:
New Panel
  • Choose InfluxDB as a query:
  • Customize the panel the way you prefer.
How to Create User with Read-Only Permission
  • Click Server Admin > Users > New user
