Version: 5.0
Getting Started with AWS IoT GreengrassV2 for Torizon
As a participant of the AWS Partner Network, Toradex offers products qualified under the AWS Device Qualification Program (DQP). See the current Toradex products under the DQP in the AWS Partner Device Catalog.
This article introduces the first steps to run AWS IoT GreengrassV2 software in Toradex modules with TorizonCore. You can run AWS IoT GreengrassV2 in a Docker container. To learn more about AWS IoT GreengrassV2, see how it works and what's new.
This article complies to the Typographic Conventions for Toradex Documentation.
Prerequisites​
GreengrassV2 Setup​
AWS Setup​
Setup your AWS account and Permissions​
Refer to the instructions at Set up your AWS Account. Follow the steps outlined in these sections to create your account and a user and get started:
Install the AWS Command Line Interface​
To install the AWS CLI on your host machine, refer to the instructions at Installing the AWS CLI v2. Installing the CLI is needed to complete the instructions in this guide.
Once you have installed AWS CLI, configure it as per the instructions in this online guide. Set the appropriate values for Access key ID, Secret access key, and AWS Region. It is recommended set Output format to "json" if you prefer.
Build and deploy Docker image with GreengrassV2​
Build the Docker image​
You need a properly configured Dockerfile to build the docker image with GreengrassV2. The following Dockerfile should be used as a base, but make sure to customize it according to your application needs.
Dockerfile
## Get base image
FROM --platform=linux/arm64 torizon/wayland-base-vivante:2
## Set build arguments
ARG GREENGRASS_RELEASE_VERSION=2.6.0
ARG GREENGRASS_ZIP_FILE=greengrass-${GREENGRASS_RELEASE_VERSION}.zip
ARG GREENGRASS_RELEASE_URI=https://d2s8p88vqu9w66.cloudfront.net/releases/${GREENGRASS_ZIP_FILE}
## Set environment variables for entrypoint
ENV TINI_KILL_PROCESS_GROUP=1 \
GGC_ROOT_PATH=/greengrass/v2
## Clean apt cache
RUN apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
## Rename torizon user to ggc_user and create home folder
RUN usermod -l ggc_user torizon
RUN groupmod --new-name ggc_group torizon
RUN rm -r /home/torizon
RUN mkdir /home/ggc_user
RUN chown -R ggc_user:ggc_group /home/ggc_user
RUN mkdir /opt/greengrassv2
RUN chown -R ggc_user:ggc_group /opt/greengrassv2
RUN mkdir /greengrass
RUN chown -R ggc_user:ggc_group /greengrass
## Install build dependencies
RUN apt-get update && apt-get install -y --no-install-recommends \
unzip && \
## Install greengrassv2 dependencies
default-jre sudo python3 tar unzip wget procps \
ca-certificates curl gnupg lsb-release && \
## Install Docker
RUN mkdir -p /etc/apt/keyrings && \
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg && \
echo "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian \
$(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
## Setup user
WORKDIR /home/ggc_user
USER ggc_user:ggc_group
## Download and unzip Greengrass v2
RUN wget -q $GREENGRASS_RELEASE_URI
RUN unzip ${GREENGRASS_ZIP_FILE} -d /opt/greengrassv2 && rm ${GREENGRASS_ZIP_FILE}
## Download and configure greengrassv2 entrypoint
RUN wget -q https://github.com/aws-greengrass/aws-greengrass-docker/raw/v2.5.3/greengrass-entrypoint.sh
RUN chmod +x greengrass-entrypoint.sh
ENTRYPOINT ["/home/ggc_user/greengrass-entrypoint.sh"]
With the Dockerfile in your build environment, run:
$ docker build -t <image-tag> .
Push the Docker image to a registry​
Make sure to be logged in in your docker registry and push the image to it:
$ docker push <image-tag>
Deploy the Docker image to the device​
You will need a docker-compose.yml file in your device to deploy the docker image.
Please, note that by using the following docker-compose.yml with ACCEPT_FSL_EULA=1 you are accepting the terms and conditions of the NXP's End-User License Agreement (EULA)
docker-compose.yml
version: '3.8'
services:
greengrass:
init: false
container_name: aws-iot-greengrass
image: <image-tag>
network_mode: "host"
environment:
- THING_NAME=default_thing_name
- THING_GROUP_NAME=default_thing_group_name
- TES_ROLE_NAME=default_tes_role_name
- TES_ROLE_ALIAS_NAME=default_tes_role_alias_name
- COMPONENT_DEFAULT_USER=default_component_user
- THING_POLICY_NAME=default_thing_policy_name
- TRUSTED_PLUGIN=default_trusted_plugin_path
- INIT_CONFIG=default_init_config
- PROVISION=true
- DEPLOY_DEV_TOOLS=true
- ACCEPT_FSL_EULA=1
- AWS_REGION=<aws-region>
- AWS_ACCESS_KEY_ID=<access-key-id>
- AWS_SECRET_ACCESS_KEY=<secret-access-key>
volumes:
- /var/run/docker.sock:/var/run/docker.sock
Make sure to fill in the information in the above docker-compose.yml file:
  • <image-tag>: The image tag that was used during the build step.
  • <aws-region>: Your chosen AWS region.
  • <access-key-id>: Your AWS access key ID, available in the ~/.aws/credentials file, from your host machine.
  • <secret-access-key>: Your AWS secret access key, available in the ~/.aws/credentials file, from your host machine. Please see the note below.
note
The credentials used by the AWS CLI are stored in plain text files and are not encrypted. It is strongly recommended that you configure file system permissions on the $HOME/.aws folder and its child folders and files to restrict access to only authorized users. Use roles with temporary credentials wherever possible to reduce the opportunity for damage if the credentials are compromised. Use long-term credentials only to request and refresh short-term role credentials.
To configure the GreengrassV2 installer arguments, you can refer to Installer Arguments and change the following values on the docker-compose.yml file:
  • THING_NAME: If not left as default_thing_name, the value is passed as the --thing-name argument.
  • THING_GROUP_NAME: If not left as default_thing_group_name, the value is passed as the --thing-group-name argument.
  • TES_ROLE_NAME: If not left as default_tes_role_name, the value is passed as the --tes-role-name argument.
  • TES_ROLE_ALIAS_NAME: If not left as default_tes_role_alias_name, the value is passed as the --tes-role-alias-name argument.
  • COMPONENT_DEFAULT_USER: If not left as default_component_user, the value is passed as the --component-default-user argument. Do not change this argument unless you also change the user and group in the Dockerfile.
  • THING_POLICY_NAME: If not left as default_thing_policy_name, the value is passed as the --thing-policy-name argument.
  • TRUSTED_PLUGIN: If not left as default_trusted_plugin_path, the value is passed as the --trusted-plugin argument.
  • INIT_CONFIG: If not left as default_init_config, the value is passed as the --init-config argument.
You can also change the field init: false to init: true, if you want to setup the GreengrassV2 container to auto-start.
To run the image:
  1. Use SSH to access your device.
  2. Copy the configured docker-compose.yml to /home/torizon on your device with scp.
  3. Run:
# docker-compose up
You should see an output similar to:
Creating aws-iot-greengrass ... done
Attaching to aws-iot-greengrasss
aws-iot-greengrass | Installing Greengrass for the first time...
aws-iot-greengrass | Running Greengrass with the following options: -Droot=/greengrass/v2 -Dlog.store=FILE -Dlog.level= -jar /opt/greengrassv2/lib/Greengrass.jar --provision true --deploy-dev-tools true --aws-region <aws-region> --start false
aws-iot-greengrass | Provisioning AWS IoT resources for the device with IoT Thing Name: [CORE_DEVICE_THING_NAME]...
aws-iot-greengrass | Creating new IoT policy "GreengrassV2IoTThingPolicy"
aws-iot-greengrass | Creating keys and certificate...
aws-iot-greengrass | Attaching policy to certificate...
aws-iot-greengrass | Creating IoT Thing "CORE_DEVICE_THING_NAME"...
aws-iot-greengrass | Attaching certificate to IoT thing...
aws-iot-greengrass | Successfully provisioned AWS IoT resources for the device with IoT Thing Name: [CORE_DEVICE_THING_NAME]!
aws-iot-greengrass | Setting up resources for aws.greengrass.TokenExchangeService ...
aws-iot-greengrass | TES role alias "GreengrassV2TokenExchangeRoleAlias" does not exist, creating new alias...
aws-iot-greengrass | TES role "GreengrassV2TokenExchangeRole" does not exist, creating role...
aws-iot-greengrass | IoT role policy "GreengrassTESCertificatePolicyGreengrassV2TokenExchangeRoleAlias" for TES Role alias not exist, creating policy...
aws-iot-greengrass | Attaching TES role policy to IoT thing...
aws-iot-greengrass | No managed IAM policy found, looking for user defined policy...
aws-iot-greengrass | No IAM policy found, will attempt creating one...
aws-iot-greengrass | IAM role policy for TES "GreengrassV2TokenExchangeRoleAccess" created. This policy DOES NOT have S3 access, please modify it with your private components' artifact buckets/objects as needed when you create and deploy private components
aws-iot-greengrass | Attaching IAM role policy for TES to IAM role for TES...
aws-iot-greengrass | Configuring Nucleus with provisioned resource details...
aws-iot-greengrass | Downloading Root CA from "https://www.amazontrust.com/repository/AmazonRootCA1.pem"
aws-iot-greengrass | Created device configuration
aws-iot-greengrass | Successfully configured Nucleus with provisioned resource details!
aws-iot-greengrass | Creating a deployment for Greengrass first party components to the device
aws-iot-greengrass | Configured Nucleus to deploy aws.greengrass.Cli component
aws-iot-greengrass | Nucleus start set to false, exiting...
aws-iot-greengrass | Making loader script executable...
aws-iot-greengrass | Starting Greengrass...
aws-iot-greengrass | Launching Nucleus...
aws-iot-greengrass | Launched Nucleus successfully.
Please take note of your CORE_DEVICE_THING_NAME that is shown in the output.
Verify Deployment​
It can take some time for the deployment to be done, to check its status, run on your host machine:
$ aws greengrassv2 list-effective-deployments --core-device-thing-name CORE_DEVICE_THING_NAME
Once the deployment is complete, you should see an output similar to:
"effectiveDeployments": [
"deploymentId": "...",
"deploymentName": "Deployment for CORE_DEVICE_THING_NAME",
"iotJobId": "...",
"targetArn": "arn:aws:iot:<aws-region>:...:thing/CORE_DEVICE_THING_NAME",
"coreDeviceExecutionStatus": "COMPLETED",
"reason": "SUCCESSFUL",
"creationTimestamp": "...",
"modifiedTimestamp": "..."
Debugging and logging​
View logs​
After verifying that the GreengrassV2 deployment was successful, you need to attach a terminal to the container. To do that:
  1. Open another SSH connection to your device.
  2. Run:
# docker exec -it aws-iot-greengrass bash
At this point you will be in a shell within the GreengrassV2 container and have access to the Greengrass CLI. To verify this, run:
## /greengrass/v2/bin/greengrass-cli help
Greengrass command line interface
--ggcRootPath=<ggcRootPath>
The AWS IoT Greengrass V2 root directory.
-h, --help Show this help message and exit.
-V, --version Print version information and exit.
Commands:
help Show help information for a command.
component Retrieve component information and stop or restart
components.
deployment Create local deployments and retrieve deployment status.
logs Analyze Greengrass logs.
get-debug-password Generate a password for use with the HTTP debug view
component.
To view the logs, run:
## /greengrass/v2/bin/greengrass-cli logs get -ld /greengrass/v2/logs
Change log level​
To change the log level, set the environment variable LOG_LEVEL in your docker-compose.yml file in the Deploy the Docker image to the device step:
docker-compose.yml
    environment:
- LOG_LEVEL=<log-level>
Further Reading​
