Torizon Updates
Torizon Platform Services is the recommended tool for managing remote and offline updates for Torizon, our easy-to-use embedded Linux platform.
Resources
Browse for Torizon Updates resources from the tabs below.
- A Toradex Computer on Module running TorizonCore.
How to Get Started With Torizon Updates
It is very simple to get started, you just need to create an account and login to our hosted dashboard:
Get Started With the Torizon PlatformIt is a good experience to just explore the dashboard, but you can of course learn more with documentation:
- Torizon Updates Overview: an overview about offline and remote updates with Torizon.
- First Steps with Torizon Remote Updates: a practical introduction to Torizon Remote Updates.
- First Steps with Secure Offline Updates: a practical introduction to Secure Offline Updates.
- Technical overview: an optional read with technical details for those who are interested in learning more.
- Quickstart Guide: there is a lesson dedicated to Torizon Remote Updates (coming soon).
- Torizon Documentation: the Torizon documentation has a section dedicated to OTA.
- TorizonCore Builder: shows how to build your own custom TorizonCore image.
- Signing and pushing TorizonCore images to Torizon OTA: present details on how to sign and push a custom generated TorizonCore image to Torizon Remote Updates using TorizonCore Builder.
- Visual Studio Code Extension for Torizon: deploy an application to the Torizon Platform Services directly from VS Code.
- Visual Studio Extension For Torizon: deploy an application to the Torizon Platform Services directly from Visual Studio.
Torizon OTA Documentation
An overview of relevant articles is presented in this tab. You can scroll through contents or click on your topic of interest below:
First Steps and Essentials, Torizon Tools and TorizonCore Customization
We use icons to help you identify the content in an article:
Visual Studio
Visual Studio Code
Command Line
Conceptual
Starting Point
Docker Concepts
Samples Repository
Technical information about Torizon Remote Updates implementation.
Article | Brief Description | |
![]() | Torizon Updates Overview | An overview of Updates with Torizon |
![]() | Torizon Updates Technical Overview | A technical overview of how Torizon implements updates |
![]() | Over-The-Air Updates | An overview of over-the-air update technologies for Toradex modules |
![]() | Quickstart Guide | Our step-by-step guide has a section dedicated to Torizon Platform |
![]() ![]() | First Steps with Torizon Remote Updates | A practical introduction to Torizon Remote Updates |
![]() ![]() | First Steps with Secure Offline Updates | A practical introduction to Secure Offline Updates |
![]() ![]() | Torizon Platform Services Web Interface | An overview of the web interface of Torizon OTA and its features |
![]() | Device Monitoring in TorizonCore | Device monitoring is a feature available in the Torizon platform to check the health and monitor the performance of a device |
![]() | Aktualizr - Modifying the Settings of Torizon OTA Client | Configure some settings on the Torizon OTA client, as the polling frequency and blocking updates on the device |
![]() ![]() | Signing and Pushing TorizonCore Packages to Torizon OTA | A step-by-step tutorial on how to build and push to Torizon OTA a custom TorizonCore image or application package for OTA Deployment |
![]() ![]() | Using Private Registries With Torizon OTA | How to deploy private registry credentials to your devices |
![]() ![]() | OSTree | An overview of a core technology used in the Torizon OTA |
The articles below show information about Torizon Tools and TorizonCore Customization to prepare an image for OTA deployment.
![]() ![]() ![]() | TorizonCore Builder Tool - Customizing TorizonCore Images | Create a custom TorizonCore image that you can use in production programming with Toradex Easy Installer, or push your changes to Torizon Platform Services |
![]() ![]() | TorizonCore Builder - Workflow | Workflow of TorizonCore Builder, with a comparison between the approaches to use the tool and diagrams to graphically present the workflow and each approach |
![]() ![]() | TorizonCore Builder VS Code Integration | How to use TorizonCore Builder from Visual Studio Code |
![]() | TorizonCore Builder Tool “build" command | Learn how to fully customize an image as a single step using the build command from TorizonCore Builder |
![]() ![]() | Device Tree Overlays on Torizon | How to modify the device tree without having to re-compile it |
![]() | Device Tree Customization Examples | Some examples of Device Tree Customization |
![]() ![]() | Pin Multiplexing - Changing Pin Functionalities in the Linux Device Tree | How to create a dts file to change the pin muxing configuration |
![]() | Building External Kernel Modules With Torizon | How to deploy an external kernel module using TorizonCore Builder with an example |
![]() | Customizing Kernel Arguments in Torizon | How to use TorizonCore Builder to customize kernel arguments in Torizon |
![]() | Splash Screen Customization on TorizonCore | Learn how to change the splash screen using initramfs |
![]() | Touch Screen Calibration (Torizon) | How to use weston-touch-calibrator to calibrate the touch |
![]() | Capturing Changes in the Configuration of a Board on TorizonCore | Use TorizonCore Builder to save and reproduce board customization |
![]() | Pre-provisioning Docker Containers onto a TorizonCore image | How to preinstall a Docker Container onto a TorizonCore image using your PC |
![]() | TorizonCore Builder - Commands Manual | Commands manual of TorizonCore Builder, showing all commands of the tool and explaining them |
![]() | TorizonCore Boot Time Optimization | How to measure and optimize TorizonCore boot time |
![]() ![]() ![]() | Reliability on Torizon | Learn how to improve reliability on TorizonCore |
![]() ![]() | How to Store Docker Data on an External Storage Device (USB/SD Card) | How to storage Docker data on an external device like an SD Card or a USB stick |
![]() | Persistent Journald Logging | How switch from in-RAM to persistent Journald logging |
![]() ![]() | Using Private Registries With Torizon Platform | How to deploy private registry credentials to your devices |
