Version: Torizon OS 7.x.y
Customizing Kernel Arguments in Torizon
The Linux Kernel of Torizon OS accepts certain boot-time arguments (parameters) that configure aspects of the kernel itself or its modules. This article briefly describes the method provided by the TorizonCore Builder tool (which is part of the Torizon Cloud) to perform such configuration.
To learn which Linux Kernel version corresponds to the latest Torizon OS versions, check the Embedded Linux Release Matrix.
To find out more about Linux Kernel Arguments, see The kernel’s command-line parameters.
Applying Kernel Arguments to a Custom Image
Approach 1: Applying Custom Kernel Arguments to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the custom kernel arguments applied, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yaml as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The directory with the kernel arguments are passed as customization: kernel: arguments.
tcbuild.yaml
# Sample configuration file:
input:
easy-installer:
# Sample customization: include or change (if already exists) key1 and key2 kernel arguments
customization:
kernel:
arguments:
- key1=val1
- key2=val2
output:
easy-installer:
Build the Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
Deploy the Custom Toradex Easy Installer Image
  • Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
Directly, through SSH
tip
warning
Torizon Cloud
warning
Approach 2: Applying Custom Kernel Arguments to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the custom kernel arguments is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different custom kernel arguments (or other customizations like different device tree overlays). As you will see, applying custom kernel arguments on an image of Torizon OS that has other customizations is just a matter of performing the apply, merge and deploy stages.
To generate a custom Toradex Easy Installer image with the desired custom kernel arguments follow the sequence of steps below.
Unpack an Input Image
You just need to execute this once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying custom kernel arguments, you can also apply a custom splash screen, a new device tree, among other possibilities.
Set the Custom Kernel Arguments
For setting the custom kernel arguments, one would simply run:
$ torizoncore-builder kernel set_custom_args "key1=val1" "key2=val2"
Kernel custom arguments successfully configured with "key1=val1 key2=val2".
tip
The command kernel set_custom_args will replace the set of arguments previously defined, so you should pass all the desired kernel arguments in a single invocation of the command.
Depending on the version of the Torizon OS image being customized, TorizonCore Builder uses different methods to preserve custom kernel arguments in the output image.
With the older method (used in Torizon OS images prior to version 7.5.0) the custom arguments are stored in a device tree overlay named custom-kargs_overlay. This overlay is visible to the user and can be affected by commands that operate on overlays. For example:
  • Once kernel arguments are configured, the dto status command shows the overlay in its output:
    $ torizoncore-builder dto status
    Enabled overlays over device tree imx6dl-colibri-eval-v3.dtb:
    - custom-kargs_overlay.dtbo
  • This overlay can be removed by the dto remove command (though the recommended approach is using kernel clear_custom_args for that). In particular, running dto remove --all will remove that overlay (along with all the others) effectively discarding custom kernel arguments. Users should take this into consideration when customizing device trees and managing overlays.
With the newer method (available since Torizon OS 7.5.0) the custom arguments are kept in an "environment file" rather than in a device tree overlay. As a result, device tree operations do not affect these arguments, and no special precautions are required when working with device tree commands.
The kernel set_custom_args section in the commands manual provides additional details about how kernel arguments are stored in the image, which users are encouraged to familiarize themselves with.
warning
With Torizon OS images prior to version 7.5.0, users should take care when working with device trees and overlays to avoid unintentionally removing the custom-kargs_overlay, which stores the custom kernel arguments.
Check the Current Set of Custom Kernel Arguments
To determine what the current custom kernel arguments are (that is, what configuration would take effect upon the execution of a union command) use:
$ torizoncore-builder kernel get_custom_args
Currently configured custom kernel arguments: "key1=val1" "key2=val2".
For more details about the kernel get_custom_args command, please check the kernel get_custom_args command in the commands manual.
Finally, it is also possible to clear any applied custom kernel arguments by doing:
$ torizoncore-builder kernel clear_custom_args
Custom kernel arguments successfully cleared.
For more details about the kernel clear_custom_args command, please check the kernel clear_custom_args command in the commands manual.
Merge Changes
Merge the kernel arguments (as well as other customizations like a splash screen or a new device tree) into the base Toradex Easy Installer image of Torizon - use whatever branch name you want.
warning
tip
warning
warning
Deploying Through the Torizon Cloud
The images with customized Kernel Arguments can be deployed using the Torizon Updates Features.
You can sign and push the custom OS image to the Torizon Cloud as an OS Package. After pushing the new custom OS image, your device can be updated with it.
This is only possible from Torizon OS 6 onward.
Verifying the New Custom Image on the Device
# sudo ostree admin status
Password:
Check the Custom Kernel Arguments
After deploying the image, you should be able to see your custom kernel arguments in the kernel arguments list. To do it, you can use the command below:
# cat /proc/cmdline
enable_wait_mode=off galcore.contiguousSize=50331648 root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash ostree=/ostree/boot.1/torizon/248c1906ffb097b9d5dd4d48f0a942a23cfd82378649edbc24ce5743291c53b0/0 key1=val1 key2=val2
Notice that in this case the custom arguments were appended to the original kernel command-line; the behavior might be different in some cases, as explained in the kernel set_custom_args section of the commands manual.
