Customization Examples
Introductionβ
This article describes the customization options available on TorizonCore Builder, through the YAML configuration file, covering the following use cases:
- Modify the OS splash screen
- Switch device trees
- Apply device tree overlays
- Install kernel modules
- Modify kernel arguments
- Capture device configuration changes
- Configure device for Torizon Cloud Provisioning
- Pre-provision containers - Pre-install Applications
Please refer to the following specific articles for additional resources:
- Commands Manual article for detailed specification of the
buildCommand. - Adjust the Configuration File article for detailed explanation about editing the customization file.
Prerequisitesβ
- A Toradex SoM with Torizon installed
- Understanding the basics of the TorizonCore Builder
- TorizonCore Builder installed on the host machine
Apply the Customization Examplesβ
The examples from this article require you to use the TorizonCore Builder build command to generate the custom image.
$ torizoncore-builder build
The produced Torizon OS image will be available at the directory configured in the output section of your YAML file. The customized image is already prepared to be flashed through the Toradex Easy Installer.
output:
easy-installer:
local: torizon-core-docker-colibri-imx6-custom-dt
Read our dedicated Build Custom Torizon OS Images article for a comprehensive explanation about building and deploying customized Torizon OS images.
Modify the OS Splash Screenβ
To customize the splash screen, add the highlighted line under the customization section of your tcbuild.yaml:
customization:
# >> Splash screen:
splash-screen: splash-screen.png
Note that the splash-screen.png file must be placed in the same folder as tcbuild.yaml. For information about supported splash screen formats and other customization methods, see Splash Screen on Torizon OS.
Switch Device Treesβ
By default, U-Boot (the bootloader) selects the device trees for development carrier boards. For example, the default device trees for Verdin SoMs are the Verdin Development Board device trees, with source files ending in *-verdin-wifi-dev.dts. To select the appropriate device tree for a different carrier board, you can specify it using the device-tree property:
# Top-level device tree source file that will be used.
# This file's name includes the name of the target SoC and carrier board.
# Note that we are including a complete device tree source file (.dts) and not a .dtsi file
customization:
device-tree:
custom: linux/arch/arm64/boot/dts/freescale/imx8mp-verdin-wifi-dahlia.dts
To learn how to locate the appropriate device tree file for your carrier board on the Linux kernel source code, see Customize Torizon OS Images. For more information about device trees, see Device Tree Technical Overview.
Apply Device Tree Overlaysβ
Use the overlays property to include device tree overlays in the image:
customization:
device-tree:
include-dirs:
# Folder that contains common kernel header files like gpio.h
- linux/include
# Folder containing overlays included by verdin-imx8mp_panel-cap-touch-7inch-dsi_overlay.dts
- device-trees/overlays
overlays:
add:
# Overlay to be applied
- device-trees/overlays/verdin-imx8mp_panel-cap-touch-7inch-dsi_overlay.dts
Depending on the header files your device tree overlay includes, such as shared macros defined in common headers, you may also need to specify include directories in the build environment using the include-dirs property. This lets TorizonCore Builder locate all dependent files during compilation. For more information, see Customize Torizon OS Images.
To understand the technical aspects of device tree overlays, see Device Tree Overlays Technical Overview.
In this sample configuration file we customize the device-tree to be deployed with an image:
# Sample configuration:
input:
easy-installer:
local: images/torizon-core-docker-colibri-imx6-Tezi_5.3.0-devel-202105+build.12.tar
customization:
device-tree:
include-dirs:
- device-trees/include/
overlays:
add:
- device-trees/overlays/colibri-imx6_atmel-mxt-connector_overlay.dts
output:
easy-installer:
This example selects the imx6dl-colibri-eval-v3.dts device tree for the image, and applies the two overlays on top of it: colibri-imx6_hdmi_overlay.dts and colibri-imx6_atmel-mxt-connector_overlay.dts.
The overlays used in this customization example are available at Toradex's device-tree-overlays repository. To get the specific overlays for your module, clone the repository following the instructions available at Build Custom Torizon OS Images.
If using Git, you can also manage external device trees from your project's repository using the Git submodules tool. This ensures that all required source files are available in your project's source tree.
The directory structure for this "project" would look like this:
βββ device-trees
βΒ Β βββ dts-arm32
βΒ Β βΒ Β βββ imx6dl-colibri-eval-v3.dts
βΒ Β βββ include
βΒ Β βΒ Β βββ dt-bindings
βΒ Β βΒ Β βββ ...
βΒ Β βββ overlays
βΒ Β βΒ Β βββ ...
βΒ Β βΒ Β βββ colibri-imx6_atmel-mxt-adapter_overlay.dts
βΒ Β βΒ Β βββ colibri-imx6_atmel-mxt-connector_overlay.dts
βΒ Β βΒ Β βββ colibri-imx6_hdmi_overlay.dts
βΒ Β βΒ Β βββ colibri-imx6_parallel-rgb-lvds_overlay.dts
βΒ Β βΒ Β βββ colibri-imx6_parallel-rgb_overlay.dts
βΒ Β βΒ Β βββ ...
βΒ Β βΒ Β βββ Makefile
βΒ Β βββ README.md
βββ images
βΒ Β βββ torizon-core-docker-colibri-imx6-Tezi_5.3.0-devel-202105+build.12.tar
βββ tcbuild.yaml
You should get the device-trees directory subtree from the Toradex supplied device-tree files (including overlays), by cloning the repositories according to the specific instructions form our Build Custom Torizon OS Images.
Install Kernel Modulesβ
TorizonCore Builder can build and install external kernel modules in your custom OS image. Specify the module's source directory in the configuration file, as shown following:
customization:
kernel:
modules:
- source-dir: <kernel-module-repository>/
autoload: no
Note that the <kernel-module-repository> must be in the same folder as tcbuild.yaml. The autoload property indicates whether the modules should load at startup. For more information, see Building External Kernel Modules with Torizon.
The build command allows you to build and install kernel modules into the deployed OS image. This is demonstrated in this configuration file:
# Sample configuration: build virtual touchscreen into the image
input:
easy-installer:
customization:
kernel:
modules:
- source-dir: virtual_touchscreen/
autoload: no
output:
easy-installer:
local: torizon-core-docker-colibri-imx6-vt
After running the build command over this configuration file, the tool would build the kernel module from the sources located in the directory virtual_touchscreen and create a custom Torizon OS image in the directory torizon-core-docker-colibri-imx6-vt. The image would then be ready to be flashed through Toradex Easy Installer.
For more general information about the subject, please refer to Building External Kernel Modules With Torizon.
Modify Kernel Argumentsβ
You can modify or include kernel arguments (parameters) in OS images through tcbuild.yaml. For example:
customization:
kernel:
arguments:
- console=ttyLP0,115200
- loglevel=3
For more information, see Customizing Kernel Arguments in Torizon.
Capture Device Configuration Changesβ
If you have made manual modifications on your Torizon OS deviceβsuch as changing the device hostname, disabling services, or changing file permissionsβyou can preserve those changes and include them on another custom OS image.
To capture the configuration changes made on the target device, run the command below - remember to replace the <remote-host-ip>, <username>, and <password> to match your target device information:
Run the
torizoncore-builder isolatecommand:$ torizoncore-builder isolate --remote-host <remote-host-ip> --remote-username <username> --remote-password <password> --changes-directory <changes-dir>For details on how the
isolatecommand works, see the Commands Manual. -
Include the extracted changes in the image through the configuration file:
tcbuild.yaml#Sample customization: insert the configuration changes made in the device
customization:
filesystem:
- <path-to-changes-directory>/
See the Capturing Changes in the Configuration of a Board on Torizon OS article for detailed instructions.
Additionally, for more details on how the isolate command works, please check the isolate command on the Commands Manual article.
Configure Device for Torizon Cloud Provisioningβ
There are cases where you want to customize an image for automatic provisioning during production programming, so your devices can be ready for using with our Torizon Cloud. The devices will automatically be registered for using our secure remote or offline update, devices monitoring, and the new features to be released.
For this, you should get the provisioning data and apply in the configuration file.
Youβll need the credentialis.zip file for the account to which you want to provision devices. Since credentials access and other sensitive data is involved, this step should be run by your system admin or those with proper access to such information.
There are two types of provisioning data:
- Shared-Data: This type of provisioning data is used for provisioning a device for offline and online updates. This data is not security-sensitive. In our system, we distribute the data as a tarball that contains the data.
- Online-Data: This type of provisioning data is used only in provisioning for online updates. This data is security-sensitive and should be handled carefully. In our system we distribute the data as a base64 encoded string.
In order to get either provisioning data, use the platform provisioning-data command can be used to fetch both types of provisioning data:
$ torizoncore-builder platform provisioning-data --credentials credentials.zip --shared-data shared-data.tar.gz --online-data DEFAULT
The command will then produce a tarball containing the shared-data and output the string that is the online-data. This data can then be stored for future provisioning use. For a detailed guide on the usage of this command please see the specific section in the commands manual
Now that you have obtained your provisioning data, you need to apply it. The idea here is that you want to create a single Torizon OS image that, when flashed to multiple devices, will allow each device to provision itself automatically.
A sample configuration file for applying the provisioning data is this:
input:
easy-installer:
local: <INPUT_IMAGE>
output:
easy-installer:
local: <OUTPUT IMAGE>
provisioning:
mode: "online"
shared-data: <SHARED-DATA TARBALL>
online-data: <ONLINE-DATA STRING>
Recall that the online-data string is sensitive information. You'll most likely want to use variable substitution, rather than inserting this string in plain text in your yaml file.
For more details see the provisioning property under the Output section of the build command's yaml file schema.
Pre-Provision Containers - Pre-Install Applicationsβ
TorizonCore Builder allows you to bundle Docker container images directly into your customized image.
Auto-Pull Containersβ
With the configuration following, TorizonCore Builder reads the specified docker-compose.yml file, pulls the referenced container images, and packages them along with the base Torizon OS image.
#Sample customization: insert pre-provisioned Docker container images
output:
easy-installer:
local: <path>
bundle:
Pre-bundled Directoriesβ
The build command also simplifies the process of bundling container images into an installer image. It is ideal for generating the image to be used during production programming and provisioning multiple devices.
If you want to install both the OS and the application during an update, you should not use the Bundling feature. Instead, you should use the synchronous update feature of Torizon Cloud.
The sample configuration file following leverages that feature:
# Sample configuration file:
input:
easy-installer:
remote: "https://artifacts.toradex.com:443/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/release/1/colibri-imx6/torizon-upstream/torizon-core-docker/oedeploy/torizon-core-docker-colibri-imx6-Tezi_5.1.0%2Bbuild.1.tar;sha256sum=5d11dc0b6be688f6a7d159280e9bca15e26bc58732724e3e1dd66b0d0a6ada08"
output:
easy-installer:
local: torizon-core-docker-colibri-imx6-with-containers
name: "My customized image with container images"
bundle:
Using this feature, the tool will fetch the container images referenced by the specified docker-compose.yml file and combine them with the installer-ready image.
If you don't want the tool to download the container images at every build command, you can download them beforehand via the torizoncore-builder bundle command, and specify the bundle output directory in the output.easy-installer.bundle.dir property. This procedure is detailed in the following steps:
Run the
torizoncore-builder bundlecommand, pointing to the Docker Compose file you want to bundle. For example:$ torizoncore-builder bundle docker-compose.yml --bundle-directory bundle --platform linux/arm64This command downloads all container images referenced in
docker-compose.ymland saves them to a directory namedbundle/. For details on how the command works, see the Commands Manual. -
Include the pre-bundled container images in your output image. For example:
tcbuild.yamloutput:
easy-installer:
local: path/to/your/custom-image-folder
bundle:
dir: bundle/
For more information about this feature, see Pre-provisioning Docker Containers onto a Torizon OS image.
Next Stepsβ
Refer to the Detailed Manual tab for a detailed description of the build command schema and its parameters.
