Version: Torizon OS 7.x.y
Install TorizonCore Builder
This article guides you on how to install TorizonCore Builder. The installation process consists of the following steps:
  • Set up your host Linux or Windows host Machine: Ensure that your development PC has all the required dependencies to run TorizonCore Builder.
  • Install TorizonCore Builder: Learn how to install it via the command line and source its environment script.
Prerequisites​
Linux Host Machine Requirements​
  • Docker Engine: Install Docker Engine.
  • Bash Shell: TorizonCore Builder may work with other shells, but we do not guarantee it.
  • SElinux Disabled: Some Linux distros like Fedora come with SELinux enabled by default, and you must disable it to use all TorizonCore Builder commands.
Windows Host Machine Requirements​
  • Windows 11 / Windows 10 version 2004 or later: TorizonCore Builder requires a Linux environment. These are the Windows versions that support WSL 2.
  • WSL 2: Install WSL 2.
As a reminder, all TorizonCore Builder commands should be run in your WSL 2 distro.
tip
You will occasionally need to transfer files to and from your WSL 2 distro and your Windows host. To do this, you can use the built-in File Explorer. You can also invoke Windows utilities from within your WSL 2 distro. For example, run:
$ explorer.exe .
This command opens File Explorer in the current directory. From there, you can copy and move files between WSL 2 and Windows.
Install TorizonCore Builder​
Follow the steps below to install TorizonCore Builder:
  1. Download the setup script into some writable directory in your system (here we use ~/tcbdir/):
    $ mkdir -p ~/tcbdir/ && cd ~/tcbdir/
    $ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
  2. Source the script:
    $ cd ~/tcbdir/
    $ . ./tcb-env-setup.sh
    This script:
    • Mounts your current directory into the container. Files outside this directory won't be accessible from inside the container.
    • Creates a Docker volume named storage, which stores project state, unpacked images, image artifacts, and other internal metadata used by TorizonCore Builder.
    • Sources a Bash completion script script for command-line auto-completion using the TAB key.
    Proxy server configuration (TorizonCore Builder 3.13.0+)
    With TorizonCore Builder 3.13.0+, when using a non-transparent proxy server:
    • Configure your Docker client according to the Docker proxy configuration page.
    • Source the script, passing extra information about your proxy (adjust the variables as needed):
      $ cd ~/tcbdir/
      $ . ./tcb-env-setup.sh -- \
      --env HTTP_PROXY="http://proxy.example.com:3128" \
      --env HTTPS_PROXY="https://proxy.example.com:3129" \
      --env NO_PROXY="*.test.example.com,.example.org,127.0.0.0/8" \
      --env DIND_FORWARD_VARS=HTTP_PROXY,HTTPS_PROXY,NO_PROXY
  3. Test whether the torizoncore-builder command is available:
    $ torizoncore-builder --help
Early-Access and Advanced Use Cases​
To see advanced use case options, run . ./tcb-env-setup.sh -h or read the project README.
The README also includes information about using the early-access version of the tool:
tip
Remember to source the setup script every time you start a new terminal (or shell instance).
