Version: Torizon OS 7.x.y
Splash Screen on Torizon OS
Torizon OS uses Plymouth splash screen running in user space. Plymouth is started from an initial minimal root file system (initramfs) very early during boot. Hence customizing the splash screen requires customizing the initramfs. Torizon OS ships with a script that allows adding a custom splash screen logo to the initramfs.
There are different phases of development with different methods for customizing the splash screen:
  • Evaluation and prototyping: The ostree-customize-plymouth.sh script included in the Torizon OS image can be used for evaluation and prototyping purposes. Important: This script is still available in Torizon OS 7 but is deprecated.
  • Development and production: you must use the TorizonCore Builder Tool.
Limitations​
The Apalis iMX8 does not have a splash screen on HDMI before Torizon OS 7.5.0. On these older versions, the splash screen is only present when using the Capacitive Touch Display 10.1" LVDS with the HDMI Device Tree Overlay disabled.
Prerequisites​
  • For changing the splash screen image:
    • The custom splash screen image needs to be a png file with a maximum size of your screen's resolution (-32 pixel in height for the waiting animation). Typically a resolution of around 600x400 is used. Currently, the default background color is always black.
  • For changing the splash screen configuration:
    • The custom splash screen configuration needs to be a standard Plymouth theme file. The default Plymouth theme configuration used by Torizon OS is defined in the spinner.plymouth file from the Plymouth theme recipe. TorizonCore Builder can also output the currently applied splash screen configuration via the splash-config dump command.
  • A Toradex SoM with Torizon installed.
  • A Torizon OS image downloaded.
Evaluation: Add a Custom Splash Screen Directly from Torizon OS​
warning
The helper script ostree-customize-plymouth.sh is deprecated and will be removed in a future major release of Torizon OS (version 8). Refer to the Development and Production: Add a Custom Splash Screen with TorizonCore Builder section for reference on customizing the system splash screen.
warning
The helper script ostree-customize-plymouth.sh can only customize the splash screen image, not the splash screen configuration.
Since the initramfs is stored in OSTree, customizing the splash screen requires a new OSTree commit. Torizon OS ships with the ostree-customize-plymouth.sh script which does most of the work. It requires three parameters:
# ostree-customize-plymouth.sh [splash] [ostree ref] [new ostree branch]
Being:
  • splash: the path to the png image.
  • ostree ref: the reference to the base tree from OSTree.
  • new ostree branch: the name of a new branch to which you will commit the changes.
warning
you are advised to always start from a vanilla Torizon OS OSTree reference before running the tool for the second time.
Get the Current OSTree Reference​
To get the reference to the base tree (typically the current running tree) you can use ostree admin status to display the current reference:
# ostree admin status
* torizon e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990.0
Version: 4.0.0-devel-20200218+build.118
origin refspec: e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
The value is displayed as origin refspec.
Create New OSTree Commit​
With the png in place and the base reference above a new OSTree commit with the customized initramfs can be created. See an example below that uses an image named fast-banana.png and creates a new branch named apalis-imx6/torizon/torizon-core-docker-customized:
# sudo ostree-customize-plymouth.sh fast-banana.png \
e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990 \
Deploy New OSTree Commit​
This new OSTree commit can be deployed using:
# sudo ostree admin deploy "apalis-imx6/torizon/torizon-core-docker-customized"
# sudo reboot
On reboot, you should be able to see the new splash screen showing up.
Revert to the Vanilla Torizon OS OSTree Reference​
The script ostree-customize-plymouth.sh "overwrites" the default splash screen by appending a new splash screen to the initramfs of the currently running root file system. This means that if the tool is used on an already customized root file system, the initramfs will append another splash screen, making the initramfs unnecessary larger.
Given the origin refspec from the previous example, run ostree admin switch [ostree ref] to revert to the vanilla Torizon OS OSTree reference:
# sudo ostree admin switch e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
# sudo reboot
Development and Production: Add a Custom Splash Screen with TorizonCore Builder​
The TorizonCore Builder Tool is the recommended method for customizing Torizon OS.
Additional prerequisites​
Installing TorizonCore Builder​
Actions that customize the splash screen configuration require a TorizonCore Builder version of at least 3.15.0.
Applying a Splash Screen to a Custom Image​
Approach 1: Applying a Splash Screen to a Custom Image: Using the Build Command​
TorizonCore Builder build command generates a custom Torizon OS image with the splash screen, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yml as default.
Custom splash screen image: Using the Build Command​
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The splash screen image is passed as customization: splash-screen.
tcbuild.yaml
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert a Splash Screen
customization:
# >> Splash screen:
splash-screen: splash.png
output:
easy-installer:
The file splash.png should be available before running the build command. A demo image can be downloaded by clicking on the link below:
Example Splash Screen Image
Custom splash screen configuration: Using the Build Command​
Similarly, this requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The splash screen configuration is passed as customization: splash-config.
tcbuild.yaml
input:
easy-installer:
#Sample customization: insert a Splash Screen configuration
customization:
# >> Splash screen configuration:
splash-config: spinner.plymouth
output:
easy-installer:
The file spinner.plymouth should be readily available before running the build command. The currently active splash screen configuration can be seen by running the following:
  • $ torizoncore-builder images unpack <path to your input Torizon OS image>
  • $ torizoncore-builder splash-config dump
The second command will output the currently active configuration found in the input Torizon OS image. The syntax and fields of this configuration file follow the standards in Plymouth. The fields in the file are fairly self-explanatory and widely used in other Linux distros.
It is possible to mix splash-screen and splash-config customization options in the same tcbuild.yaml file.
Build The Custom Toradex Easy Installer Image​
Build The Custom Image​
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
Deploy The Custom Toradex Easy Installer Image​
  • Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
Toradex Easy Installer​
Copy the output image into a USB stick and follow the steps in the Toradex Easy Installer article linked preceding. The copy of the output image can be done with the command following:
Directly, through SSH​
In this case, before deployment the output image needs to be unpacked, using the command following:
To deploy it directly to the board, through SSH, use the command following:
tip
warning
Torizon Cloud​
To deploy it to the Torizon Cloud Update Service, use the command following:
warning
Approach 2: Applying a Splash Screen to a Custom Image: Using Standalone Commands​
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the splash screen is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different splash screens (or other customizations like different device tree overlays). As you will see, applying a splash screen to an image of Torizon OS that has other customizations is just a matter of performing the apply, merge and deploy stages.
To generate a custom Toradex Easy Installer image with the splash screen follow the sequence of steps below.
Unpack an Input Image​
You just need to execute this once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying a splash screen, you can also apply an external kernel module, a new device tree, among other possibilities.
Apply The Splash Screen​
To apply the splash screen image file, in this case splash.png, to the custom Toradex Easy Installer image, run the command below:
/storage/splash/usr/share/plymouth/themes/spinner/
splash screen merged to initramfs
A demo splash.png image can be downloaded by clicking on the link below:
For more details about the splash command, please check the spash command in the commands manual.
Apply The Splash Screen Configuration​
To apply the splash screen configuration file, in this example spinner.plymouth, to the custom Toradex Easy Installer image, run the command below:
$ torizoncore-builder splash-config set spinner.plymouth
78069 blocks
Splash screen configuration updated
To get a starting configuration file to work with, run the following commands:
For more details about the splash-config command, please check the spash-config command in the commands manual.
Merge Changes​
Merge the splash screen (as well as other customizations like an external kernel module or a new device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
warning
First, to generate a Toradex Easy Installer image, into the output directory torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM, use the command following:
Copy the output image into a USB stick and follow the steps in the Toradex Easy Installer Tool article linked preceding. The copy of the output image can be done with the command following:
tip
warning
Torizon Cloud Remote Update Service​
To deploy it to the Torizon Cloud Remote Update Service, use the command following:
warning
Verifying The New Custom Image On The Device​
# sudo ostree admin status
Password:
Splash Screen on Third-Party Displays​
Adding a third-party or custom display driver with TorizonCore Builder has a limitation regarding the splash screen. For an explanation of the limitation and how to work around it, refer to the Setting up Displays with Torizon article.
