Torizon Connector
Torizon Connector is an installation script designed to help you set up the Torizon software stack on Debian-based host systems, such as Debian, and Ubuntu. It enables you to manage the Torizon environment from familiar apt-based environments and connect to Torizon Cloud.
Key Features
Torizon Connector helps you to streamline the development process on Debian/Ubuntu hosts:
- It fetches and installs the key components of the Torizon ecosystem.
- It provides an unified, script-based approach for configuring the necessary tooling, packages, and base images needed for developing with Torizon.
Torizon Connector provides the following features for production programming, without any changes to your existing OS or hardware.
- Secure cloud connectivity
- Sreamlined operations
- Scalable fleet management are enabled
Setup & Installation
If you're running a Debian or Ubuntu-based OS, simply run the Torizon Connector command in your terminal to start leveraging Torizon Cloud features:
sudo sh -c "$(curl -sSL https://raw.githubusercontent.com/torizon/torizon-plugin-installer/main/install-torizon-connector.sh)"
Additional Resources
For more details on the Torizon Connector, refer to the following links:
