Torizon OS Upgrade Notes
In this article, you will learn about the technical details of Torizon OS releases which impact customers when upgrading.
Torizon OS releases are maintained according to our Embedded Linux Support Strategy.
Release Details and Upgrade Notes
In this section, you find notes on the impact of updating to a newer Torizon OS release.
Torizon OS 7.4.0
Torizon OS 7.4.0 is a quarterly release from the Torizon OS 7 series.
- All users of the early Torizon OS 7 monthly pre-releases should update to this release until it is superseded. All previous monthly pre-releases will not be patched - maintenance releases are based on the latest quarterly.
- RPCbind service is now disabled by default. This disables a potential attack vector, and thus aligns with our commitment of security by default. If needed, the related service needs to be enabled.
Read the Torizon OS 7.4.0 news for a complete list of updates and highlights for this release.
Torizon OS 6.8.4
Torizon OS 6.8.4 is a maintenance release of the Torizon OS 6 series.
- All users of the Torizon OS 6 series should update to this release until it is superseded. All previous Torizon OS 6.X releases will not be patched - maintenance releases are based on the latest quarterly.
Torizon OS 7.3.0
Torizon OS 7.3.0 is a quarterly release from the Torizon OS 7 series.
- New subsystem update type for module fusing was introduced. For more details, please refer to In-field Upgrades to Secure Boot on Torizon OS
Read the Torizon OS 7.3.0 news for a complete list of updates and highlights for this release.
Torizon OS 6.8.3
Torizon OS 6.8.3 is a maintenance release of the Torizon OS 6 series.
Torizon OS 7.2.0
Torizon OS 7.2.0 is a quarterly release from the Torizon OS 7 series.
- Remote Access Client (a.k.a. RAC) is enabled by default. For more details, please refer to Remote Access
Read the Torizon OS 7.2.0 news for a complete list of updates and highlights for this release.
Torizon OS 6.8.2
Torizon OS 6.8.2 is a maintenance release of the Torizon OS 6 series.
Torizon OS 7.1.0
Torizon OS 7.1.0 is a quarterly release from the Torizon OS 7 series.
- The lockbox count limit increased from 300 to 4800. If you use Secure Offline Updates and you plan to have more than 300 lockboxes in your Torizon Cloud over time, you must have upgraded to Torizon OS 7.1.0 or newer by the time you reach this limit.
Read the Torizon OS 7.1.0 news for a complete list of updates and highlights for this release.
Torizon OS 6.8.1
Torizon OS 6.8.1 is a maintenance release of the Torizon OS 6 series.
Torizon OS 7.0.0
Torizon OS 7.0.0 is the first quarterly release from the Torizon OS 7 series.
All users of the Torizon OS 6 series should upgrade to Torizon OS 7. There are available instructions for Upgrading from Torizon OS 6.x to Torizon OS 7.x.
If you are still on TorizonCore 5: First, upgrade from TorizonCore 5 to Torizon OS 6, then, Upgrade to Torizon OS 7.x, as direct upgrade path is not supported.
The aktualizr-data-proxy used in Torizon 6.4.0 and older for Device Monitoring has been disabled in Torizon 7:
- If you have a custom
/etc/fluent-bit/fluent-bit.conffile, make sure to update the[OUTPUT]section:
# From
[OUTPUT]
name tcp
port 8850
format json_lines
match *
# To
[OUTPUT]
name http
match *
host dgw.torizon.io
port 443
uri monitoring/fluentbit-metrics
format json
tls on
tls.verify off
tls.ca_file /usr/lib/sota/root.crt
tls.key_file /var/sota/import/pkey.pem
tls.crt_file /var/sota/import/client.pem
Retry_Limit 10- If you didn't customize the file
/etc/fluent-bit/fluent-bit.conf, it will be automatically updated and you don't need to take any action.
Wi-Fi Access Point (AP) configuration via NetworkManager has been disabled due to issues between NetworkManager and the AP interface. You must use hostapd moving forward. Learn how to use hostapd on Networking with Torizon OS.
The userspace utility to manage the CPU frequency has been replaced from cpufrequtils to cpupower. Learn how to use cpupower on CPU Frequency and DVFS (Linux).
In the OS, neofetch has been replaced with fastfetch. In the Debian Containers for Torizon, it is scheduled to be replaced as well. As this is a development utility, no real impact is expected with this change.
The new major 4 release of Torizon Containers is to be used with Torizon 7 and the concept of SoC-specific containers is introduced. Containers are now either platform-specific, which has specific userspace applications to be used in conjunction with a downstream kernel (such as the ones present in the AM62 and iMX8 families of modules) or an upstream kernel (such as the ones shipping with the iMX6 and iMX7 families).
- Users should upgrade to the container corresponding to their platform by bumping the major tag to
4and adding the platform prefix append to the image name, which can be-imx8or-am62or none for the upstream platforms. For example, users migrating fromweston-vivante:3should instead useweston-imx8:4and a similar pattern applies to other containers. - Users currently running projects from
torizon/debian:4should, in conjunction with choosing an appropriate base image for your SoM, as described above (debian-imx8:4,debian-am62:4ordebian:4), should not use the codename in the image tag anymore (meaning, removing the-bookwormportion).
Read the Torizon OS 7.0.0 news for a complete list of updates and highlights for this release.
Torizon OS 6.8.0
Torizon OS 6.8.0 is the last quarterly release of the Torizon OS 6 series and has new features.
Read the Torizon OS 6.8.0 release news for a complete list of updates and highlights for this release.
Torizon OS 6.7.0
Torizon OS 6.7.0 is a quarterly release from the Torizon OS 6 series.
- Support for setting a custom device name logic on Provisioning at Scale has been added. Learn how to use it on Production Programming with Torizon - Customizing the Device Name and ID.
- Stable containers for Verdin AM62 are released. You are strongly encouraged to use a version corresponding to the CT_TAGS for the Torizon OS 6.7.0. Learn more about the compatiblity between Torizon OS and Containers on Torizon Containers Tags and Versioning.
- The Fluent Bit vulnerability CVE-2024-4323 has been patched. Learn more in the Security Notice About CVE-2024-4323 (Fluent Bit).
- The OpenSSH vulnerability CVE-2024-6387, also known as regreSSHion has been patched.
Read the Torizon OS 6.7.0 release news for a complete list of updates and highlights for this release.
Torizon OS 6.6.1
Torizon OS 6.6.1 is a quarterly release from the Torizon OS 6 series.
- All users of the Torizon OS 6 series should update to this release until it is superseded. All previous Torizon OS 6.X (formerly named TorizonCore) releases will not be patched - maintenance releases are based on the latest quarterly.
- If your product has a cellular modem, consider tweaking the default ModemManager configuration so the number of connection retries is set to infinite, as documented on Modem Support - Set Cellular Connection Retries.
- Online and offline updates can now be enabled both at the same time. Learn how to do it on How to Use Secure Offline Updates with Torizon OS - Configure Device for Offline Updates.
- A new sample for Hardware-accelerated video playback and encoding on NXP i.MX 8 SoMs has been published. Documentation is available on How to use Gstreamer on Torizon OS and the sample is available in the GitHub repository toradex/torizon-samples.
Read the Torizon OS 6.6.1 release news for a complete list of updates and highlights for this release.
Torizon OS 6.5.0
Torizon OS 6.5.0 is a quarterly release from the Torizon OS 6 series.
- If your product has low or unstable connection to the internet and you perform remote updates, consider tweaking the default configuration to make your updates more robust, as documented on Configuring Options for Low-Bandwidth Connections.
- Device monitoring data buffering is now available. The default values are a reference implementation. If you use device monitoring and your device has intermittent connection to the internet, it is recommended that you adjust the parameters to your use case constraints, as documented on Data Buffering.
- eMMC lifespan has been added to the default device monitoring metrics. If you use device monitoring, review whether it makes sense to follow the default or remove this metric.
- .NET 8 containers for Torizon are released, following the .NET 8 release announcement:
- You are encouraged to migrate your .NET 6 project to .NET 8 before it reaches End-Of-Life (EOL) by the end of 2024, according to the Microsoft's .NET and .NET Core Support Policy.
- Consult the Microsoft documentation to learn about What's new in .NET 8 and Breaking changes in .NET 8.
- We recommend you develop your .NET 8 project with our Visual Studio Code IDE Extension for Torizon. .NET 8 templates are available for various use cases: C# console, ASP.NET Blazor, Avalonia, Uno Platform, and Slint.
- A Qt 6 template is available for the VS Code IDE Extension for Torizon, providing an improved user experience that is built on top of the Debian Containers provided in the previous quarterly 6.4.0 release.
Read the Torizon OS 6.5.0 release news for a complete list of updates and highlights for this release.
Torizon OS 6.4.0
Torizon OS 6.4.0 is a quarterly release from the Torizon OS 6 series.
- Qt 6 Debian Containers for Torizon are available and support hardware acceleration. Updates to the related documentation and the VSCode Torizon template should happen after this release. Before this update, projects based on this template will rely on the software-rendered implementation.
- If your use case relies on hardware acceleration and you can't wait for the template and docs update, you may want to try the new containers by replacing your project Dockerfile's
FROMstatement to use one of the following:torizon/qt6-waylandfor SoMs based on NXP i.MX 6/6ULL/7 or;torizon/qt6-wayland-vivantefor SoMs based on NXP i.MX 8/8X/8M Mini/8M Plus. - For testing purposes, you can run examples with the
torizon/qt6-wayland-examples-vivantecontainer. Thetorizon/qt6-wayland-examplescontainer is not available because the Qt 6 examples package is not available in the Debian feed. - Python bindings are not yet easy-to-use. As a hint, you may use PyQt6 which already has Debian packages available, or PySide6 which doesn't have the packages available but on the other hand has a license that may better suit your product. See a comparison on PyQt6 vs PySide6.
- The Debian Containers for Torizon were rebuilt against the Debian 12.1 point release. You are encouraged to update the Debian Containers used in your project to our latest containers release.
Read the Torizon OS 6.4.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.3.0
TorizonCore 6.3.0 is a quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 6 series should update to this release until it is superseded. All previous TorizonCore 6.X releases will not be patched - maintenance releases are based on the latest quarterly.
- An alternative method for configuring Wi-Fi Access Point (AP) and hotspot has been introduced due to a bug that prevents NetworkManager instructions to work. Learn how to apply it on Networking with TorizonCore - Wi-Fi access point mode - Method 2: Hostapd.
- Debian Containers for Torizon based on Debian Bookworm are available with the major tag
3. Even though the previous Debian Bullseye containers with the major tag2are expected to work, only the newer ones are supported in TorizonCore 6. Read the article TorizonCore Containers Tags and Versioning for more details on how the compatibility between containers and TorizonCore is defined. Since this is the first release of the Debian Bookworm containers, all of the points below are considered breaking changes between TorizonCore 5 and 6:- A breaking change has been introduced on how to start the Weston and Browser containers. The up-to-date commands are available on Debian Containers for Torizon - Debian With Weston Wayland Compositor, Web Browser / Kiosk Mode with TorizonCore - Running Chromium and Web Browser / Kiosk Mode with TorizonCore - Running Cog.
- The GitHub repository torizon-containers supersedes and unifies all the content from debian-cross-toolchains, debian-docker-images, debian-dotnet-development-images, and rt-validation. With a regular workflow, you will build your own docker images on top of our pre-built images provided on Docker Hub, and thus you won't be affected by this change. Nevertheless, if you have chosen to rebuild our images from source, you must use the new repository from now on.
- GLX support on Xwayland and gst-plugins-base1.0 for i.MX 8/8X/8M Mini/8M Plus has been removed from our Debian packages, as it was done by NXP in their forks of these packages. Glamor support for hardware-accelerated 2D rendering is available and you must plan to switch to using it - though due to the bug xwayland: glamor support broken on iMX8 it is currently falling back to software rendering.
Read the TorizonCore 6.3.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.2.0
TorizonCore 6.2.0 is a quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 5 series can upgrade to TorizonCore 6. Upgrade instructions are available on Upgrading from TorizonCore 5.x to TorizonCore 6.x.
- The
torizon/debian-shellcontainer has been deprecated in TorizonCore 6. The impact should be minimal since thetorizon/debiancontainer is an easy-to-migrate replacement, as can be seen in the List of Container Images for Torizon. To migrate, check the packages installed on torizon/debian-shell and install the ones you rely on to your container based ontorizon/debian.
Read the TorizonCore 6.2.0 release news for a complete list of updates and highlights for this release.
TorizonCore 6.1.0
TorizonCore 6.1.0 is the first quarterly release from the TorizonCore 6 series.
- All users of the TorizonCore 6 series should update to this release until it is superseded. All previous monthly pre-releases will not be patched - maintenance releases are based on the latest quarterly.
- All users of the TorizonCore 5 series should upgrade to TorizonCore 6. There are available instructions for Upgrading from TorizonCore 5.x to TorizonCore 6.x.
- Colibri SoMs: the spidev overlay has been disabled by default, due to a conflict with the SPI-to-CAN transceiver on the Colibri Evaluation Board. If you use spidev, you must enable the corresponding overlay. Read the issue TOR-2746 in our issue tracker to learn more.
- The ecosystem around TorizonCore 6 has limitations. If you have experience with TorizonCore 5, read the release news below to learn what are the limitations.
- You should not rely on the
debian-shellcontainer in TorizonCore 6, as we have deprecated it. The impact should be minimal since thedebiancontainer is an easy-to-migrate replacement, as you can check in our List of Container Images for Torizon. To migrate, check the packages installed on debian-shell and install the ones you rely on into your container based ondebian.
Read the TorizonCore 6.1.0 news and the TorizonCore 6.0.0-devel-202210 news for a complete list of updates and highlights for this release, as well as why 6.0.0 was not a quarterly release.
TorizonCore 5.7.2
TorizonCore 5.7.2 is a maintenance release of the 5 series which supersedes 5.7.0.
- All users of previous versions of the 5 series should update to this version until it is superseded.
- This release enables bootloader updates and allows users to upgrade from TorizonCore 5 to 6, by using it as a bridge. Learn more on Bootloader updates article.
Read the TorizonCore 5.7.2 release news for a complete list of updates and highlights.
TorizonCore 5.7.0
TorizonCore 5.7.0 is the Latest Quarterly Release of the 5 series.
- According to our support strategy, all previous quarterly releases will not be patched - maintenance releases are based on the latest quarterly.
- The TorizonCore team only tests updating from the immediately previous TorizonCore release. In this case, from 5.6.0 to 5.7.0. If you plan to update from any other previous release, you must validate it, since it is not a supported scenario.
Read the TorizonCore 5.7.0 news for a complete list of updates and highlights.
TorizonCore 5.6.0 and older
Upgrade notes were released starting from TorizonCore 5.7.0 onward. For older releases, please read the corresponding TorizonCore news on toradex.com:
