C/C++ Development and Debugging on TorizonCore Using Visual Studio Code
Introductionβ
This article explains How to do C/C++ Development on Torizon, including running and debugging applications on the device, using the Visual Studio Code Extension for Torizon. It briefs on how to create a new project, add development libraries to the SDK and runtime libraries to the target, switch between debug and release configuration, and more.
Through the article, we configure the project as if we want to use a GPIO. It is a good use case because you have to:
- Add a development package to the SDK
- Add a library to the application
- Grant hardware access to the GPIO banks.
Optional: Notes About the GPIO Exampleβ
If you are actually interested in using a GPIO in C, after going through this article you can replace the hello-world source-code with the GPIO example in C provided in our torizon-samples repository, disregarding the Dockerfiles. You can learn more about the libgpiod examples and API calls on How to Use GPIO on TorizonCore: C Language Examples.
Import an Existing Projectβ
Please refer to the dedicated article How to Import a C/C++ Application to Torizon, but before you do it, it is still recommended that you go through the current article steps and create a hello world, to get used to the Torizon practical workflow.
Prerequisitesβ
- Read the article Visual Studio Code Extension for Torizon.
- Toradex Hardware with TorizonCore installed.
- C/C++ extension for Visual Studio Code
- Remote - Containers extension for Visual Studio Code
- (only if you use cmake) CMake Tools extension for Visual Studio Code
Create a New Projectβ
Watch a short video summarizing the process described in this section:
In summary, you must open the command palette on Visual Studio Code and then type Torizon/C-C++: Create C/C++ application
to create an application:
You will be prompted some extra information before the project is fully setup:
- Application name.
- Parent directory to create your application under. The extension will create a new directory with your project name under it.
- Select the application template that is the best fit for your project.
- It will setup VS Code to use the buildsystem from the template, saving you a lot of initial configuration time.
- In the example above, we have selected
Makefile-based Project
but feel free to choose the most appropriate for you.
- Select the right target architecture (arm32v7 for 32-bit processors and arm64v8 for 64-bit) and purpose, depending on if your application has a graphical interface or not.
- Choose a user. This is the user that will run the application inside the container.
- By default, the Toradex containers provide you with two options:
torizon
androot
. - Even inside the container, for security reasons, you are advised to run as
torizon
whenever possible. Learn more on the Torizon Best Practices Guide.
- Select a configuration between
debug
andrelease
. Since we want to deploy and debug our test application, please selectdebug
.- Later on in this article you will learn how to switch between
debug
andrelease
The extension will build an SDK container, running on your development machine, that will provide the toolchain and all the libraries needed to build your application.
After a few minutes, your folder will be re-opened inside the container (notice the green box in the bottom-left corner of the Visual Studio Code window) and you'll be ready to start developing:
Configure Projectβ
Understand how to add libraries and more in the next subsections.
Switch Between Debug and Release Modesβ
caution
don't confuse release container with debug and release modes, which only affect the binary that will be compiled by the SDK. You are allowed to deploy a debug binary into a release container, though it may not be the best idea.
If you are in the debug configuration, run the command Torizon C/C++: Switch to release configuration
If you are in the release configuration, run the command Torizon C/C++: Switch to debug configuration
How the compiler will be invoked for each mode is defined in the file .vscode/tasks.json
created by the new project template. You may need to make adjustments either to this file or to the build files (Makefile, CMake file, Autotools file) according to your project's peculiarities.
Add Libraries Available on Debian Feedsβ
For a C/C++ application, we will need to add packages:
- `devpackages: headers and libraries that should be linked at build time. They are added to the SDK container.
extrapackages
: libraries and components that are dynamically linked with our application or executed on the target.
As an example, we will add support for libgpiod, used to access GPIO pins from user mode.
To add devpackages
- Open the Torizon configuration page and edit the
devpackages
configuration by clicking on the pen icon. - As an example, add the package
libgpiod-dev:#%platform.debian-arch%#
- Notice that you have to specify CPU architecture. The expression
will evaluate to eitherarm64
orarmhf
depending on the project configuration. - If you only foresee using one architecture while developing your project, you can use it instead of
- You can add a list of space-separated packages, as
package1:#%platform.debian-arch%# package2:#%platform.debian-arch%# package3:#%platform.debian-arch%#
- Once you changed this setting the editor will ask you if you want to rebuild the SDK container. We will need an updated container to be able to build our application using libgpiod, so select the option that will rebuild the SDK container immediately.
devpackages
are installed inside the SDK container (this is why you need to specify an architecture suffix if they are not multi-architecture), they will allow you to build your code on your development machine.
Thanks to Debian multi-architecture support, all the native libraries we will need to cross-compile our application will be installed and ready to use.
To add extrapackages
extrapackages
libgpiod2
- Notice that you don't need to specify a suffix, since the container will be built for the same architecture than the device.
package1 package2 package3
extrapackages
are installed inside the container that will run on the target and provide runtime components required to run your application. Usually, you will have one devpackage (headers and libs) and one extrapackage (runtime components), but this is not a strict rule. Some libraries may have a single development package but may be splitted in multiple runtime ones, each one with some "sub-features".
tip
You are responsible for including headers and linking to libraries. For example, in the GPIO demo, you must include -lgpiod
. It depends on how you are building your project, invoking GCC directly, or using different build methods - Makefiles, Cmake, make, and possibly others.
Add Debug Symbols and Source Code From Debian Feedsβ
Later on, during debugging, you may find out that you need to debug a library that you have installed from the Debian feeds. To do that with GDB, you will need:
- Debug symbols: at least, provides a better stack trace
- Source code: provides the ability to step into library functions
tip
This information is only useful if you need to step into functions from libraries installed from the Debian feeds while debugging. For most projects, this is not required.
To enable debug symbols, the easiest way is to use debuginfod. It will automatically download the symbols for all libraries loaded by GDB on-demand.
While this is very convenient, keep in mind that it will increase the startup time of the debug session every time you need to rebuild the SDK, until the cache is populated. In a complex project with several libraries, it may take about 10 additional minutes.
In the IDE Extensions, open the file .devcontainer/devcontainer.json
and add the "DEBUGINFOD_URLS": "https://debuginfod.debian.net"
environment variable to containerEnv
"containerEnv": {
To add source code, you must use apt-source to download the source for each library individually.
While debuginfod should be able to download the sources for you, due to the way Debian packaging is setup, this is not possible.
The libsdl2
package will be used as an example. Add the following content to the property sdkpreinstallcommands
RUN printf "deb-src http://deb.debian.org/debian bullseye main\ndeb-src http://security.debian.org/debian-security bullseye-security main\ndeb-src http://deb.debian.org/debian bullseye-updates main\n" >> /etc/apt/sources.list && cd /usr/src && apt-get -y update && apt-get source libsdl2-2.0-0
You must also pass the path to the library source to GDB by creating a .gdbinit file. Add the following content to the property sdkpostinstallcommands
RUN printf "directory /usr/src/\ndirectory /usr/src/libsdl2-2.0.14+dfsg2\n" > home/torizon/.gdbinit
To apply the new configuration, rebuild the SDK container by running Remote-Containers: Rebuild container
from the command palette.
Hardware Accessβ
The content from this section is a case study from the Torizon Best Practices Guide, therefore you must read it for a better understanding of why it must be done.
Earlier in this article, you have set the user to torizon
. To access hardware from the container you will need to mount gpiochip devices inside the container and add the torizon
user to the gpio
group, allowing applications to access gpio.
In the configuration window press the +
icon next to the [ ] devices
entry and insert the device path /dev/gpiochip0
Repeat the operation for all the gpiochip devices you need to access. For example, on Colibri iMX7 you have 7 devices, numbered from 0 to 6:
# ls /dev/gpiochip* -la
crw-rw-r-- 1 root gpio 254, 0 Jun 17 06:39 /dev/gpiochip0
crw-rw-r-- 1 root gpio 254, 1 Jun 17 06:39 /dev/gpiochip1
crw-rw-r-- 1 root gpio 254, 2 Jun 17 06:39 /dev/gpiochip2
crw-rw-r-- 1 root gpio 254, 3 Jun 17 06:39 /dev/gpiochip3
crw-rw-r-- 1 root gpio 254, 4 Jun 17 06:39 /dev/gpiochip4
crw-rw-r-- 1 root gpio 254, 5 Jun 17 06:39 /dev/gpiochip5
crw-rw-r-- 1 root gpio 254, 6 Jun 17 06:39 /dev/gpiochip6
You also need to add the torizon
user to the gpio
group. Groups are mirrored between the base OS and the Debian containers for Torizon. Edit the buildcommands
property and set it to RUN usermod -a -G gpio torizon
Build, Clean, Deploy and Other Tasksβ
When creating a Torizon project, some useful commands are set by default on .vscode/tasks.json
to invoke the buildsystem commands to build, clean, deploy, install and possibly other commands or variations. Our "higher level" commands described in the next sections will often call them under the hood, and you won't need to run them.
But, if you are importing an existing project and adapting it to the Torizon extension, or if you want to make sure your binaries are being rebuilt from scratch while switching between debug and release modes, it may be useful to run those commands. You will need to run on the command palette Tasks: Run Task
and it will list the available commands to be run. For our Makefile-base project we have deploy
, build_debug
, build_release
and clean
The build command is bind by default to Ctrl + Shift + B
, which is a useful means to run it.
Run Build Commands From the Command-lineβ
Remember that the SDK runs inside a container, therefore you cannot enter the project directory on your PC and simply run those commands. Accessing the command-line inside the container is made easy by VS Code, just click the +
button New Terminal
. Keep in mind that the applications installed on your computer will not be available, if you need to install any package with apt, add it to the devpackages
on the Configurations view of the Torizon tab.
All terminals you open from Visual Studio Code will run inside your Debian-based SDK container, even if you are running Windows as your main OS. You can execute build commands directly there, such as make clean
for instance. Some advantages of using Visual Studio code tasks:
- The command output will be parsed and you could reach a code line reported in an error message by just clicking on the message itself.
- You don't need to remember the commands.
Deploy and Debugβ
After configuring your project, you can now deploy and debug it.
By default, the debugger breaks on the entry point of the application. If you don't want it, just change the value of the variable stopAtEntry on .vscode/launch.json
, inside your project folder, from true
to false
Since the rest is common to all languages supported by the extension, please refer to the section Deploy and Debug from the article Visual Studio Code Extension for Torizon.
Deploy and Releaseβ
Before focusing on the process, you can optionally switch to release mode and clean the build, as described in previous sections of this article, to make sure that the binaries added to the release container are actually also stripped of debug symbols.
After going through the process of deploying and debugging the application, you can now deploy and release it. Since this is common to all languages supported by the extension, please refer to the section Deploy and Release from the article Visual Studio Code Extension for Torizon.
Torizon Configurationβ
This section shows the possible settings for the extension.
Those tags can usually be modified using the IDEs plugins user interface, but for some specific scenarios, it may be required to edit them manually inside the YAML configuration files.
Tag | Type | Description |
platform.id | string | Unique id of the platform (folder name) |
platform.name | string | Mnemonic name of the platform |
platform.version | string | Version of the platform |
platform.folder | path | Absolute path of the folder where platform configuration is stored (can be used to add files to a container) |
platform.baseimage | string | Base image of the container template (used in FROM clause of Dockerfile) |
platform.sdkbaseimage | string | Base image of the SDK template (can be empty if the platform does not support an SDK) |
platform.runtimes | string[] | Runtimes supported by the image. Currently supported runtimes are: ccpp, ccpp-no-ssh, python3, dotnet, aspnet |
platform/application.ports | key/value pairs | Ports exposed by the container (those configured by application configuration will be merged with those provided by the platform, replacing those with same keys and adding others ) |
platform/application.volumes | key/value pairs | Volumes mounted in the container (where "key "is the local path or volume name, "value" is the path inside the container and, optionally, ",ro" to mount read-only) |
platform/application.devices | string[] | List of paths of devices that should be mapped inside the container (ex: /dev/gpiochip0) |
platform/application.networks | string[] | List of networks that should be connected to the container. For a network created by a docker-compose script associated with the appplication configuration you've to prepend "#%application.id%#_" to the actual name) |
platform/application.extraparams | key/value pairs | This tag can be used to add specify some additional custom settings. Check docker python API documentation of container.run method for a list of the supported parameter. "Key" should be parameter name, "value" must be YAML representation of the value. For example to set host network mode, add "network_mode" as key and "host" as value. |
platform/application.startupscript | relative path | The script that will be launched before starting the container, tags can be used inside the script. The script must be in the same folder as platform/application config file or in a subfolder, path must be relative. If the script is specified for both platform and application, only the application one is executed (but it can invoke the platform one that will be parsed and copied to the target anyway). |
platform/application.shutdownscript | relative path | A script that will be launched after the container has been stopped. Tags can be used inside the script. The script must be in the same folder as platform/application config file or in a subfolder. If the script is specified for both platform and application, only the application one is executed (but it can invoke the platform one that will be parsed and copied to the target anyway). |
platform/application.dockercomposefile | relative path | The docker-compose script that will be used to start other containers required to run the application, tags can be used inside the script. The script must be in the same folder as platform/application config file or in a subfolder. The path must be relative. If the compose file is specified for both platform and application, only the application one is used. |
application.id | string | Application unique id (used also as a prefix for docker-compose created resources like volumes or networks) |
application.expose | docker command | Ports exposed by the application in the format: "EXPOSE NN NN" Where NN are port number (ex: "EXPOSE 80 8080) |
application.arg | docker command | Docker build arguments in the format: ARG NAME=VALUE. You can also specify multiple values. This can be useful only if you plan to use the generated dockerfile in a standalone build |
application.env | docker command | Environment variables in the format: ENV NAME=VALUE. Multiple entries can be specified and VALUE can contain other tags (ex: ENV FOLDER="/home/dummy" FILE="filename") |
application.preinstallcommands | docker command | Commands that will be executed during container build before any package installation. The format must be the one used in Dockerfiles. This can be used to add Debian package feeds to apt list, add security keys, etc. |
application.extrapackages | string | Additional packages that should be installed inside the container. You can specify multiple packages separated by spaces. |
application.devpackages | string | Development packages that will be installed in the SDK container. If a package has architecture-specific versions youβll have to specify the correct architecture. ex: libopencv:armhf or libopencvf:aarch64 |
application.sdkpackages | string | Additional packages that will be installed in the SDK container. This can be used to install additional tools or compilers. |
application.buildfiles | docker command | This command can be used to add additional files to the image using the ADD or COPY command. Files must be placed inside the application configuration folder. |
application.buildcommands | docker command | Command that will be executed after having installed all packages and having configured the debugger and the services. This will give you a chance to change configuration before the actual command is executed |
application.targetfiles | docker command | Command that will be executed at the end of the build, can be used to add files to the container (ex: providing pre-configuration for services or overriding the default configuration files) |
application.targetcommands | docker command | Command executed when the container runs, this may be used to override execution of the application in release containers |
application.appname | string | mnemonic name of the application, for application create using Visual Studio Code it will match folder name |
application.exename | string | relative path (from application install folder) of the exe started when the container starts. Used only by VSCode |
application.appargs | string | optional arguments that should be passed to the application |
application.username | string | username used to run the container CMD. Other commands will be executed as root. |
application.sdkpreinstallcommands | docker command | Command executed before installing packages into the SDK container can be used to add Debian feeds or keys |
application.sdkpostinstallcommands | docker command | Command executed after devpackages and skdpackages have been installed |
application.main | string | Used only for python application. Provides the name of the python file that container the main entry point |
Both applications and platforms provide a generic entry named βprops" where you can specify your own properties that will be replaced as tags using the same logic applied for standard tags.
In the extension UI, those will be referenced as "custom properties".
You can define your custom tags and use them in your dockerfile templates or inside other tags.
Example: How to Use a GPIO: Source Code and Makefileβ
First of all, move to the folder created on the previous steps and replace the content of your C file with the GPIO example in C provided in our torizon-samples repository. You can ignore the Dockerfiles.
You will also need to add a reference to libgpiod in your Makefile. Open "Makefile" in the editor and locate the following lines:
helloworld: $(OBJ)
$(CC) -o $@ $^ $(CFLAGS)
Change them to:
helloworld: $(OBJ)
$(CC) -o $@ $^ $(CFLAGS) -lgpiod
