Version: 5.0
Torizon Application Development With Visual Studio
Visual Studio is an IDE for Windows. Toradex provides the Visual Studio Extension for Torizon to make your development life easier.
Resources
Browse for Visual Studio on Torizon resources from the tabs below.
Requirements
Everything you need is a Computer on Module with Torizon installed and a Windows desktop PC for development. You must have the Windows Subsystem for Linux 2 (WSL2) and Docker Desktop installed and configured.
How to Start
Following our Step-by-step Quickstart Guide for fully supported modules is the easiest way to get you set up in no time.
Alternatively, you can follow the instructions below if you prefer a summarized version. This is only recommended if you have some knowledge of Torizon and Visual Studio.
Installation
Install Visual Studio 2019 and the following workloads:
  • Desktop development with C++
  • Linux development with C++
Install workload - Desktop development with C++
Install workload - Linux development with C++
Install the Visual Studio Extension for Torizon:
The latest versions of the Toradex Torizon Support extension can be found on the Visual Studio marketplace, in two versions:
Close all running instances of Visual Studio. Choose one of Torizon extensions from the above, download and install it.
tip
The extension is available for Visual Studio 2019 only!
Check that the installation was successful by opening the extension list under Extensions > Manage Extensions:
Torizon Extension for Visual Studio
Add a Target Device
In Visual Studio, go to View > Other Windows > Torizon devices and add a target device from either the network or the serial port:
Torizon Devices Window
The board will reboot once you add it.
Download the Base SDK and Containers
Select Tools > Download/update base and sdk containers:
Download Base and SDK Containers
this operation may take some time, especially if you create a new C/C++ project. This is due to the download of the SDK.
Create an Application From a Template
Enable the Torizon toolbar on Visual Studio selecting Tools > Customize, scroll down the list, select "Torizon Toolbar" and hit Close:
Torizon Toolbar
Create a New Project and select Torizon C/C++ Application from the Visual C++ category:
New Project Dialog
Make sure to mark the checkbox Place solution and project in the same directory:
Configure Your New Project
Deploy and Debug
Either choose Debug > Deploy and debug Torizon or click on Deploy and Debug Torizon Application on the Torizon Toolbar:
Deploy and Debug
Additional Resources
Proceed to the Documentation tab on this page.
