Cloud Sqs Lib API
Contains function declarations to be used to access AWS Cloud SQS Services Colibri Modules [PXAxxx, Tegra T20], WinCE 6.0 / 7.0 . More...
Macros | |
| #define | AWS_SQS_ACCESS_ID_MAX_LENGTH 20 |
| AWS Account ID string Length. | |
| #define | AWS_SQS_SECRET_KEY_MAX_LENGTH 40 |
| AWS Account Secret Kay String Length. | |
| #define | AWS_SQS_OWNER_ID_MAX_LENGTH 12 |
| AWS Account Owner ID String Length. | |
| #define | AWS_SQS_SIGNATURE_HASH_LENGTH 32 |
| #define | AWS_SQS_SIGNATURE_STRING_LENGTH 44 |
| #define | SQS_QUEUE_NAME_MAX_LENGTH 80 |
| #define | SQS_MAX_TIME_STRING_LENGTH 24 |
| #define | SQS_MESSAGE_ID_LENGTH 100 |
| #define | SQS_MESSAGE_DELAY_SECONDS_MAX 900 |
| #define | SQS_MESSAGE_BODY_MAX_LENGTH (64 * 1024) |
| #define | SQS_RECIEPT_HANDLE_MAX_LENGTH 1024 |
| #define | SQS_ATTRIBUTE_NAME_BUFFER_SIZE 24 |
| #define | SQS_HTTP_RESPONSE_DATA_BUFFER_SMALL (2 * 1024) |
| #define | SQS_HTTP_RESPONSE_DATA_BUFFER_LARGE (4 * 1024) |
| #define | SQS_HTTP_ARGUMENT_BUFFER_SMALL (2 * 1024) |
| #define | SQS_HTTP_ARGUMENT_BUFFER_LARGE (4 * 1024) |
| #define | SQS_STRING_TO_SIGN_BUFFER_SMALL (2 * 1024) |
| #define | SQS_STRING_TO_SIGN_BUFFER_LARGE (4 * 1024) |
| #define | URL_ENCODED_RECEIPT_HANDLE_BUFFER (4 * 1024) |
| #define | SQS_HANDLE_MEMORY_ALLOCATION (4 * 5) |
| #define | QUEUE_ATTRIBUTE_VISIBILITY_TIMEOUT 1 |
| #define | QUEUE_ATTRIBUTE_MAXIMUM_MESSAGE_SIZE 2 |
| #define | QUEUE_ATTRIBUTE_MESSAGE_RETENTION_PERIOD 3 |
| #define | QUEUE_ATTRIBUTE_DELAY_SECONDS 4 |
Functions | |
| BOOL | SqsOpenQueue (char *accessID, char *secretKey, char *path, char *accountOwnerID, char *queueName, HSQS *sqsQueue) |
| BOOL | SqsCloseQueue (HSQS *sqsQueue) |
| BOOL | SqsSendMessage (HSQS sqsQueue, char *message, DWORD delaySeconds, char *messageID, DWORD messageIDSize) |
| BOOL | SqsReceiveMessage (HSQS sqsQueue, char *attributeName, BYTE maxNumberOfMessages, DWORD visibilityTimeout, char *message, char *messageID, char *recieptHandle) |
| BOOL | SqsDeleteQueue (HSQS sqsQueue) |
| BOOL | SqsCreateQueue (HSQS sqsQueue) |
| BOOL | SqsGetQueueUrl (HSQS sqsQueue, char *dataOut, DWORD dataOutSize) |
| BOOL | SqsListQueues (HSQS sqsQueue, char *queueNamePrefix, char *filePath) |
| BOOL | SqsFindQueue (const char *filePath, char *dataOut, DWORD dataOutSize, DWORD *pointerToNextTopic, DWORD fileSize) |
| BOOL | SqsGetQueueAttributes (HSQS sqsQueue, char *dataOut, DWORD dataOutSize) |
| BOOL | SqsSetQueueAttributes (HSQS sqsQueue, DWORD attributeName, int attributeValue) |
| BOOL | SqsDeleteMessage (HSQS sqsQueue, char *receiptHandle) |
| BOOL | SqsChangeMessageVisibility (HSQS sqsQueue, char *receiptHandle, DWORD visibilityTimeoutValue) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG [Software License Agreement]
- Author:
- agp
- Version
- Rev:
- 1154
- Date
- Date:
- 2012-11-08 19:56:19 +0530 (Thu, 08 Nov 2012)
Function Documentation
| BOOL SqsChangeMessageVisibility | ( | HSQS | sqsQueue, |
| char * | receiptHandle, | ||
| DWORD | visibilityTimeoutValue | ||
Changes Message's Visibility Timeout attribute
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [in] receiptHandle Pointer to the string returned by call to SqsReceiveMessage() [in] visibilityTimeoutValue New value for timeout, Range [0 - 900] Seconds
- Return values
TRUE Success FALSE See GetLastError()
| BOOL SqsCloseQueue | ( | HSQS * | sqsQueue | ) |
Deletes already opened SQS Queue Handle
- Parameters
- Return values
| BOOL SqsCreateQueue | ( | HSQS | sqsQueue | ) |
Creates a Queue
- Parameters
- Return values
| BOOL SqsDeleteMessage | ( | HSQS | sqsQueue, |
| char * | receiptHandle | ||
Deletes a Message from a Queue
- Parameters
- Return values
| BOOL SqsDeleteQueue | ( | HSQS | sqsQueue | ) |
Deletes the Queue
- Parameters
- Return values
| BOOL SqsFindQueue | ( | const char * | filePath, |
| char * | dataOut, | ||
| DWORD | dataOutSize, | ||
| DWORD * | pointerToNextTopic, | ||
| DWORD | fileSize | ||
Finds one by one Queue details stored in a local file as a result of function call to SnsListQueues()
File must be initialized by calling SqsListQueues()
- Parameters
[in] filePath Local file path in which queue list data is saved [out] dataOut Pointer to the allocated memory to store returned queue detail, user need to allocate memory [in] dataOutSize Size of the allocated memory pointed by dataOut [in,out] pointerToNextTopic Points to next location of detail, to find 1st in the list put NULL [in] fileSize Size of the file in bytes, pointed by filePath
- Return values
| BOOL SqsGetQueueAttributes | ( | HSQS | sqsQueue, |
| DWORD | dataOutSize | ||
Gets Queue Attributes
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [out] dataOut Pointer to the allocated memory to hold Queue attributes data returned by function, user need to allocate memory [in] dataOutSize Size of the allocated memory
- Return values
| BOOL SqsGetQueueUrl | ( | HSQS | sqsQueue, |
Gets Queue Url
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [out] dataOut Pointer to the allocated memory to hold Queue string returned by the function, user need to allocate memory [in] dataOutSize Size of the allocated memory for dataOut
- Return values
| BOOL SqsListQueues | ( | HSQS | sqsQueue, |
| char * | queueNamePrefix, | ||
| char * | filePath | ||
Lists all Queues in a local file starting with prefix mentioned
Queues are stores in a local file
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [in] queueNamePrefix Prefix example "test" to get a list of all queues starting with test or
"t" to get list of all queue starting with letter t[in] filePath Local file path in which queue list data will be saved
- Return values
| BOOL SqsOpenQueue | ( | char * | accessID, |
| char * | secretKey, | ||
| char * | path, | ||
| char * | accountOwnerID, | ||
| char * | queueName, | ||
| HSQS * | sqsQueue | ||
Opens Handle for SQS Queue, the returned sqsQueue Handle is required as an input parameter to every Sqs function call
- Parameters
[in] accessID AWS Access ID [20 Characters] [in] secretKey AWS Secret Key [40 Characters] [in] path AWS SQS path [in] accountOwnerID 12 digit unique ID number like, AWS Access ID [in] queueName Queue names must be constructed using only uppercase/lowercase ASCII letters,
numbers, underscore, hyphen, and must be between 1 and 80 characters long.[out] sqsQueue Handle to hold various sqs related parameters.
- Return values
| BOOL SqsReceiveMessage | ( | HSQS | sqsQueue, |
| char * | attributeName, | ||
| BYTE | maxNumberOfMessages, | ||
| DWORD | visibilityTimeout, | ||
| char * | message, | ||
| char * | messageID, | ||
| char * | recieptHandle | ||
Receives message from an existing Queue
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [in] attributeName Valid String values: All | SenderId | SentTimestamp | ApproximateReceiveCount | ApproximateFirstReceiveTimestamp [in] maxNumberOfMessages Maximum number of messages to return, 1 to 10(maximum) [in] visibilityTimeout The duration (in seconds) that the received messages are hidden
from subsequent retrieve requests after being retrieved by a SqsReceiveMessage() request.[out] message Pointer to the received Message as string (64KB maximum) [out] messageID Pointer to the received Message's ID as string, maximum length = 100 [out] recieptHandle Pointer to the recieptHandle as string, it is required by SnsDeleteMessage() call. Maximum length = 1024
- Return values
TRUE Success FALSE See GetLastError() AttributeName, visibilityTimeout, maxNumberOfMessages - working in default mode only for now (kept it for future use)
Put NULL for these input parameters
| BOOL SqsSendMessage | ( | HSQS | sqsQueue, |
| DWORD | delaySeconds, | ||
| DWORD | messageIDSize | ||
Sends a message to the Queue
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [in] message The message you want to send to the queue. Maximum length is 64KB [in] delaySeconds Number of seconds to delay the message
Messages with a positive delay seconds becomes available for processing after the delay time has elapsed[out] messageID Successful call to this function will put message ID string on the memory pointed by this pointer, user need to allocate memory [in] messageIDSize Size of the memory allocated for messageID
- Return values
| BOOL SqsSetQueueAttributes | ( | HSQS | sqsQueue, |
| DWORD | attributeName, | ||
| int | attributeValue | ||
Sets Queue Attribute
- Parameters
[in] sqsQueue Handle returned by call to SqsOpenQueue() [in] attributeName Valid values can be from 1 to 4, user should use macros QUEUE_ATTRIBUTE_XXXXXXXXX [in] attributeValue Value associated with attributeName
- Return values
