CoProc Lib API
Library to provide access to the ARM Coprocessor registers. More...
Macros
##define CPL_VER_MAJ 2 CoprocLib Major Library Version. More...
#define CPL_VER_MIN 2 CoprocLib Minor Library Version. More...
#define CPL_VER_BUILD 0 CoprocLib Library Build Version. More...
#define PXA 1 #define TEG 2 #define TYPE_PXA270 0x11 #define TYPE_MONAHANS 0x02 #define TYPE_PXA320 0x02 #define TYPE_PXA300XT 0x07 #define TYPE_PXA300 0x08 #define TYPE_PXA310 0x09 #define TYPE_TEGRA2 0x411FC09 #define TYPE_TEGRA3 0x412FC09 #define MODULE_FAMILY_COLIBRI 0 #define MODULE_FAMILY_APALIS 1
Functions | |
DWORD | getCLKCFG () |
void | setCLKCFG (DWORD val) |
DWORD | getPWRMODE () |
void | setPWRMODE (DWORD val) |
DWORD | getCPUID () |
DWORD | getPROCID () |
DWORD | getL2Enabled () |
void | CPLGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
DWORD | GetSoCType () |
DWORD | getModuleFamily () |
Detailed Description
- Copyright
- Copyright (c) 2013 Toradex AG
- Author:
- kia
- Rev:
- 2101
- Date:
- 2014-03-10 14:27:38 +0100 (Mo, 10 Mrz 2014)
- Target Platforms:
- Colibri PXAxxx, T20, T30 & Apalis T30
#define CPL_VER_BUILD 0 |
#define CPL_VER_MAJ 2 |
#define CPL_VER_MIN 2 |
#define MODULE_FAMILY_APALIS 1 |
#define MODULE_FAMILY_COLIBRI 0 |
#define PXA 1 |
#define TEG 2 |
#define TYPE_MONAHANS 0x02 |
#define TYPE_PXA270 0x11 |
#define TYPE_PXA300 0x08 |
#define TYPE_PXA300XT 0x07 |
#define TYPE_PXA310 0x09 |
#define TYPE_PXA320 0x02 |
#define TYPE_TEGRA2 0x411FC09 |
#define TYPE_TEGRA3 0x412FC09 |
Function Documentation
void CPLGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
Get the revision of this CoprocLib
- Parameters
[out] major library version. Set this parameter to NULL if not required. [out] minor library version. Set this parameter to NULL if not required. [out] library build number. Set this parameter to NULL if not required.
DWORD getCLKCFG | ( | ) |
Get Core Clock Configuration (Coprocessor 14, cr6) [for PXA only]
On other CPUs the function also returns cp14.cr6, but this register has a different meaning.
See ARM documentation for details.
- Returns
- CLKCFG. (content of cp14.cr6)
DWORD getCPUID | ( | ) |
Request extended CPUID (Coprocessor 15, register c0)
- Returns
- value read from coprocessor 15 register c0.
Refer to the ARM documentation for details.
DWORD getL2Enabled | ( | ) |
Request whether L2 cache is enabled or disabled
- Return values
true,: L2 cache is enabled false,: L2 cache is disabled
DWORD getModuleFamily | ( | ) |
Request module family type (Colibri / Apalis)
- Returns
- CPU_TYPE: MODULE_FAMILY_COLIBRI or MODULE_FAMILY_APALIS
See defines at the beginning of coproclib.h for details.
DWORD getPROCID | ( | ) |
Detect the CPU type this code is running on
- Returns
- CPU ID. See defines at the beginning of coproclib.h for details.
DWORD getPWRMODE | ( | ) |
Get PWRMODE (Coprocessor 14, cr7) [for PXA only]
On other CPUs the function also returns cp14.cr7, but this register has a different meaning.
- Returns
- PWRMODE. (content of cp14.cr7)
DWORD GetSoCType | ( | ) |
Request SoC family type (PXA / Tegra)
- Returns
- CPU_TYPE: SOC family i.e PXA or Tegra
void setCLKCFG | ( | DWORD | val | ) |
Set Core Clock Configuration (Coprocessor 14, cr6) [for PXA only]
On other CPUs the function also sets cp14.cr6, but this register has a different meaning.
- Parameters
[in] CLKCFG. Value to store into cp14.cr6
void setPWRMODE | ( | DWORD | val | ) |
Set PWRMODE (Coprocessor 14, cr7) [for PXA only]
On other CPUs the function also sets cp14.cr7, but this register has a different meaning.
- Parameters
[in] PWRMODE. Value to store into cp14.cr7
