How to use ADC library
ADC library provides easy access to use ADC available on Toradex Computer Modules.
Use cases are:
  • Temperature sensor
  • Light sensor
  • and many more..
ADC Library
We provide free Library for ADC including sample source code.
ProjectModule compatibilityLanguageLibrary Version
ADCPXA / TegraCToradex CE Library (Old)
ADCVFxx / iMX6CToradex CE Library (New)
ADCPXA / TegraC#Toradex CE Library (Old)
ADCVFxx / iMX6C#Toradex CE Library (New)
Schematic
Demo application in C
This application demonstrates how to read analog inputs.
  • Follow this tutorial up to step 9 to create a new VC++ project. Edit the code as follows:
  • To include ADC library into project refer this article.
  • Build and deploy solution.
Output
Demo application in C#
  • Download ADC demo source code from above links.
  • Download and Install .NET Compact Framework on device from here.
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_adc_demo > Properties > Devices.
  • Uncheck Deploy the Latest version of the .NET Compact Framework (including Service Packs).
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_adc_demo > Properties > Build.
  • Check Allow unsafe code.
  • Build and Deploy solution.
