How to use ADC PWM I2C library in VCSharp
This article aims to help the developer, to use Toradex libraries (ADC, PWM and I2C) in Visual C#.
How to use ADC Library in VCSharp​
ADC library gives easy access to 4 channels of Analog to Digital converter available on Toradex module.
Use cases are:
  • Temperature sensor
  • Light sensor
  • Accelerometer
  • and many more..
ADC hardware setup​
Connect Analog signals to the analog input pins (SODIMM pin 2, 4, 6 and 8) on X14 header of Colibri Evaluation Board V3.1A.
ADC demo application​
This application demonstrates how to read analog input using ADC.
  • Download ADC demo source code from here.
  • Download and Install .NET Compact Framework on device from here.
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_adc_demo > Properties > Devices.
  • Uncheck Deploy the Latest version of the .NET Compact Framework (including Service Packs).
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_adc_demo > Properties > Build.
  • Check Allow unsafe code.
  • Build and Deploy solution.
  • On the Toradex Module go to My Device > Program Files > vcsharp_adc_demo. Double click on the vcsharp_adc_demo.exe to run the application.
Analog values measured from ADC channels are displayed on respective text boxes and vertical slider controls.
How to use PWM Library in VCSharp​
PWM library gives easy access to 4 channel of PWM available on Toradex module.
Use cases are:
  • LCD back-light control
  • Servo motor control
  • and many more..
Refer this article for more information about PWM channels available on Colibri modules.
PWM hardware setup​
Connect PWM Channels (SODIMM Pins 59, 28, 30 and 67) on Colibri Evaluation Board V3.1A to Oscilloscope.
NOTE - For PXA3xx PWM channel 1 is available at SODIMM pin 152, refer PWM reference table from this article.
PWM demo application​
This application demonstrates how to produce PWM signal at different PWM Channels.
  • Download PWM demo source code from here.
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_pwm_demo > Properties > Devices.
  • Build and deploy solution.
  • On the Toradex Module go to My Device > Program Files > vcsharp_pwm_demo. Double click on the vcsharp_pwm_demo.exe to run the application.
  • Select the frequency and duty-cycle for different channels and click on Set Button.
All channels are set at frequency of 50Hz on Colibri T20 with different duty- cycle as shown in the picture below.
All channels are set at duty-cycle of 50% on Colibri T20 with different Frequency as shown in the picture below.
How to use I2C Library in VCSharp​
I2C Library provides easy access to I2C interface available on Toradex modules.
Some of the devices that can be interfaced using I2C library are:
  • EEPROM
  • Real Time Clock
  • I/O expander
  • Touch screen LCD
  • Audio codec
  • and many more..
I2C hardware setup​
In this demo EEPROM 24C256 has been interfaced with Colibri Evaluation Board V3.1A. Connect SDA and SCL pin of EEPROM chip to I2C_SDA (SODIMM pin 194) and I2C_SCL (SODIMM pin 196) respectively available on X9 connector of Colibri Evaluation Board V3.1A.
I2C demo application​
This application demonstrates how to use Toradex I2C library to read time, day of the week, date from the Real Time Clock (RTC) and to perform read & write operation on EEPROM chip.
  • Download I2C demo source code from here.
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_i2c_demo > Properties > Devices.
  • Uncheck Deploy the Latest version of the .NET Compact Framework(including Service Packs).
  • Navigate to Solution Explorer in visual studio, Right Click on vcsharp_i2c_demo > Properties > Build.
  • On the Colibri Module go to My Device > Program Files > vcsharp_i2c_demo. Double click on the vcsharp_i2c_demo.exe to run the application.
Follow the steps as mentioned below:
  • Select the device as RTC or EEPROM.
  • Set the address of selected device eg: set 104 as the address if RTC is selected and set 80 as the address if EEPROM is selected.
  • Set the operation (Read/Write) to be performed.
  • Click on the button (Read/Write) to perform read or write operation.
Reading time, date and day from RTC.
Writing Data on EEPROM.
Reading Data from EEPROM.
