Int Lib API
Header file for the Interrupt Library. More...
Macros
##define INT_VER_MAJ 2 #define INT_VER_MIN 6 #define INT_VER_BUILD 0 #define GPIO_EDGE_RISING 1 Defines for Interrupt Edge Detect. More...
#define GPIO_EDGE_FALLING 2 #define GPIO_LEVEL_HIGH (GPIO_EDGE_RISING | 4) Defines for Interrupt Level Detect. More...
#define GPIO_LEVEL_LOW (GPIO_EDGE_FALLING| 4)
Functions | |
HANDLE | LoadIntChainHandlerCompat (LPCWSTR lpFilename, LPCWSTR lpszFunctionName, BYTE bIRQ) |
BOOL | FreeIntChainHandlerCompat (HANDLE hInstance) |
BOOL | InterruptInitializeCompat (DWORD idInt, HANDLE hEvent, LPVOID pvData, DWORD cbData) |
void | InterruptDisableCompat (DWORD idInt) |
void | InterruptDoneCompat (DWORD idInt) |
LPVOID | CreateStaticMappingCompat (DWORD dwPhysBase, DWORD dwSize) |
BOOL | KernelLibIoControlCompat (HANDLE hModule, DWORD dwIoControlCode, LPVOID lpInBuf, DWORD nInBufSize, LPVOID lpOutBuf, DWORD nOutBufSize, LPDWORD lpBytesReturned) |
DWORD | GetGPIOIrq (DWORD dwGpio) |
BOOL | SetGPIOIrqEdge (DWORD dwGpio, DWORD dwEdge) |
DWORD | RequestSysInterrupt (DWORD dwIrq) |
BOOL | ReleaseSysIntr (DWORD dwSysIntr) |
void | INTGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2013 Toradex AG
- Author
- andy.kiser
- Rev
- 2863
- Date
- 2015-06-26 17:18:52 +0200 (Fr, 26 Jun 2015)
- Target Platforms:
- PXAxxx, Txx
#define GPIO_EDGE_FALLING 2 |
#define GPIO_EDGE_RISING 1 |
#define GPIO_LEVEL_HIGH (GPIO_EDGE_RISING | 4) |
#define GPIO_LEVEL_LOW (GPIO_EDGE_FALLING | 4) |
#define INT_VER_BUILD 0 |
#define INT_VER_MAJ 2 |
#define INT_VER_MIN 6 |
enum tegraIrqNumbers |
Tegra IRQ numbers.
Function Documentation
LPVOID CreateStaticMappingCompat | ( | DWORD | dwPhysBase, |
DWORD | dwSize | ||
Win CE 5.0/6.0/7.0 compatible version of CreateStaticMapping()
- Parameters
[in] dwPhysBase Physical Base [in] dwSize Size
- Return values
Virtual address
BOOL FreeIntChainHandlerCompat | ( | HANDLE | hInstance | ) |
Win CE 5.0/6.0/7.0 compatible version of FreeIntChainHandler()
- Parameters
[in] hInstance Instance Handle
- Return values
True Success False Failure
DWORD GetGPIOIrq | ( | DWORD | dwGpio | ) |
Get the IRQ for a specific GPIO Pin
- Parameters
[in] dwGpio GPIO Pin Number
- Return values
IRQ Number
void InterruptDisableCompat | ( | DWORD | idInt | ) |
Win CE 5.0/6.0/7.0 compatible version of InterruptDisable()
- Parameters
[in] idInt Interrupt ID
void InterruptDoneCompat | ( | DWORD | idInt | ) |
Win CE 5.0/6.0/7.0 compatible version of Interrupt()
- Parameters
BOOL InterruptInitializeCompat | ( | DWORD | idInt, |
HANDLE | hEvent, | ||
LPVOID | pvData, | ||
DWORD | cbData | ||
Win CE 5.0/6.0/7.0 compatible version of InterruptInitialize()
- Parameters
[in] idInt Interrupt ID [in] hEvent Event Handle [in] pvData Pointer to data buffer [in] cbData Size of data buffer
- Return values
void INTGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
Outputs library version
- Parameters
[out] verMaj Major version number. Set this parameter to NULL if not required [out] verMin Minor version number. Set this parameter to NULL if not required [out] build Build number. Set this parameter to NULL if not required
BOOL KernelLibIoControlCompat | ( | HANDLE | hModule, |
DWORD | dwIoControlCode, | ||
LPVOID | lpInBuf, | ||
DWORD | nInBufSize, | ||
LPVOID | lpOutBuf, | ||
DWORD | nOutBufSize, | ||
LPDWORD | lpBytesReturned | ||
Win CE 5.0/6.0/7.0 compatible version of KernelLibIoControl()
- Parameters
[in] hModule Module Handle returned by LoadIntChainHandlerCompat() [in] dwIoControlCode IO Control Code [in] lpInBuf Pointer to Input Buffer [in] nInBufSize Input Buffer Size in bytes [in] lpOutBuf Pointer to Output Buffer [in] nOutBufSize Output Buffer Size [out] lpBytesReturned Number of bytes returned
- Return values
HANDLE LoadIntChainHandlerCompat | ( | LPCWSTR | lpFilename, |
LPCWSTR | lpszFunctionName, | ||
BYTE | bIRQ | ||
Win CE 5.0/6.0/7.0 compatible version of LoadIntChainHandler()
- Parameters
[in] lpFilename Pointer to Filename [in] lpszFunctionName Function Name String [in] bIRQ IRQ Number
- Return values
HANDLE Instance Handle
BOOL ReleaseSysIntr | ( | DWORD | dwSysIntr | ) |
Release the specified system interrupt
- Parameters
[in] dwSysIntr System Interrupt Number
- Return values
DWORD RequestSysInterrupt | ( | DWORD | dwIrq | ) |
Get the System Interrupt Number for the specified IRQ
- Parameters
[in] dwIRQ IRQ Number
- Return values
BOOL SetGPIOIrqEdge | ( | DWORD | dwGpio, |
DWORD | dwEdge | ||
Set the GPIO Interrupt Edge Detect
- Parameters
[in] dwGpio GPIO Pin Number [in] dwEdge GPIO_EDGE_RISING or GPIO_EDGE_FALLING
- Return values
