Mem Lib API
Library function to set memory timings for the Colibri PXA270 and PXA3xx.
Macros | |
| #define | MEM_VER_MAJ 1 |
| major library version | |
| #define | MEM_VER_MIN 0 |
| minor library version | |
| #define | MEM_VER_BUILD 1 |
| build revision | |
| #define | MEMTYPE_FLASH 0 |
| #define | MEMTYPE_SRAM 1 |
| #define | MEMTYPE_BURST4 2 |
| #define | MEMTYPE_BURST8 3 |
| #define | MEMTYPE_VLIO 4 |
| #define | MEMBUS_32BIT 0 |
| #define | MEMBUS_16BIT 1 |
| #define | MEMBUFFER_SLOW 0 |
| #define | MEMBUFFER_FAST 1 |
Functions | |
| BOOL | SetMemTimingsEx (DWORD dwBaseAddr, MSCCFG *pTimings) |
| void | MEMGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG
- Version
- $Rev$
- Date
- $Date$
- Target Platforms:
- PXAxxx
| #define MEM_VER_BUILD 1 |
build revision
| #define MEM_VER_MAJ 1 |
| #define MEM_VER_MIN 0 |
| #define MEMBUFFER_FAST 1 |
| #define MEMBUFFER_SLOW 0 |
| #define MEMBUS_16BIT 1 |
| #define MEMBUS_32BIT 0 |
| #define MEMTYPE_BURST4 2 |
| #define MEMTYPE_BURST8 3 |
| #define MEMTYPE_FLASH 0 |
| #define MEMTYPE_SRAM 1 |
| #define MEMTYPE_VLIO 4 |
Function Documentation
| void MEMGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
Returns the library Version
- Parameters
[out] pVerMaj major version number.
Set this parameter to NULL if not required.[out] pVerMin minor version number.
Set this parameter to NULL if not required.[out] pBuild build number.
- Return values
TRUE Success FALSE Failure
| BOOL SetMemTimingsEx | ( | DWORD | dwBaseAddr, |
| MSCCFG * | pTimings | ||
Set the memory timings for a particular chip select
- Parameters
[in] dwBaseAddr Base address of the memory region that should be configured.
valid addresses are: (PXA270) 0x04000000 0x0C000000 0x10000000
(PXA3xx) 0x14000000 0x16000000 0x17000000[in] pTimings requested timings. See params.h for details
- Return values
