Mouse Cursor
Hide the Mouse Cursor
Hide Mouse Cursor by Registry Setting
You can hide the mouse cursor in the Display driver registry settings.
Open RegEdit by going to Start > Programs > ColibriTools > RegEdit
Make the following change:
- For Colibri T20/T30, Apalis T30
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\NVDDI]
"HwCursor"=dword:0
- For Colibri PXAxxx, VFxx, and iMX7
[HKEY_LOCAL_MACHINE\Drivers\Display\Colibri]
"Cursor"=dword:0
- For Colibri iMX6, Apalis iMX6
[HKEY_LOCAL_MACHINE\Drivers\Display]
"Cursor"=dword:0
Save the registry using SaveReg in ColibriTools.
Restart the module.
Hide Mouse Curser Globally From an Application
You can call an escape code to globally enable/disable the mouse cursor.
#define ESCAPECODEBASE 100000
#define MOUSECURSOR (ESCAPECODEBASE + 20)
DWORD old_cursor=0;
DWORD new_cursor=0;
// Get Cursor Status
ExtEscape(GetDC(NULL), MOUSECURSOR, 0, NULL, 4, (char*)&old_cursor);
// Disable Cursor
new_cursor=0;
ExtEscape(GetDC(NULL), MOUSECURSOR, 4, (char*)&new_cursor, 4, (char*)&old_cursor);
// Enable Cursor
new_cursor=1;
Using escape codes is not supported on iMX6
Hide the Mouse Cursor for one Application
There is an API call to hide the mouse cursor for only one application
ShowCursor(FALSE);
