NRESET IN
The nRESET_IN pin (also RESET_EXT) is used to reset the Colibri module.
Common Specification
- It has to be asserted for at least 35ms for proper resetting the module.
- Low Voltage max. 0.4V
- High Voltage min. 2.3V
- It is weak Pull-up'd on the Colibri modules. If externally used, use an additional 10k Pull-up.
Also the Voltage monitoring can reset the module if the voltage drops.
Specification for the different modules
Colibri PXA270 with TPS65020
- Time Low Min. 35ms (Deglitch)
- High Voltage Min. 1.37V
- Low Voltage Max. 0.4V
Colibri PXA3xx with MAX8660
- Time Low Min. 1 uS
- High Voltage Min. 1.4V
Colibri PXA3xx with LP3972
Time Low Min. tdb
High Voltage Min. 2.3V
Low Voltage Max. 0.5V
Colibri T20
- Time Low Min. 16 uS
- Time Low Max. 60 mS
