PWM Lib API
Library to support Pulse Width Modulation (PWM)
Macros
##define PWM_VER_MAJ 2 Version Info.
#define PWM_VER_MIN 1#define PWM_VER_BUILD 2#define COLIBRI_PWM1 0#define COLIBRI_PWM2 1#define COLIBRI_PWM3 2#define COLIBRI_PWM4 3#define APALIS_PWM1 3#define APALIS_PWM2 2#define APALIS_PWM3 1#define APALIS_PWM4 0
Functions | |
void | InitPWM (DWORD pwm, DWORD prescale, DWORD period) |
void | SetPWMDuty (DWORD pwm, DWORD duty) |
void | SetPWMDutyPercentage (DWORD pwm, DWORD duty) |
void | DeInitPWM (DWORD pwm) |
void | PWMGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
#define APALIS_PWM1 3 |
#define APALIS_PWM2 2 |
#define APALIS_PWM3 1 |
#define APALIS_PWM4 0 |
#define COLIBRI_PWM1 0 |
#define COLIBRI_PWM2 1 |
#define COLIBRI_PWM3 2 |
#define COLIBRI_PWM4 3 |
#define PWM_VER_BUILD 2 |
#define PWM_VER_MAJ 2 |
Version Info.
#define PWM_VER_MIN 1 |
Function Documentation
void DeInitPWM | ( | DWORD | pwm | ) |
Deinitialise PWM Controller
- Parameters:
[in] pwm,: channel to use (0-3)
void InitPWM | ( | DWORD | pwm, |
DWORD | prescale, | ||
DWORD | period | ||
Initialise PWM Controller (0-3)
- Parameters:
[in] prescale,: scale factor for the 13Mhz Clock (1-64) [in] period,: period length in scaled clocks units. Note - This is fixed for Tegra 2 i.e. 256
void PWMGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
get the library version
- Parameters:
Out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. Out] pVerMin: Returns the minor version number. Set this parameter to NULL if not required. Out] pBuild: Returns the build number. Set this parameter to NULL if not required.
void SetPWMDuty | ( | DWORD | pwm, |
DWORD | duty | ||
Assign duty cycle in PWM Controller
- Parameters:
[in] pwm,: channel to use (0-3) [in] duty,: high time in scaled clocks units for each period i.e. 256
void SetPWMDutyPercentage | ( | DWORD | pwm, |
DWORD | duty | ||
Assign percentage duty cycle in PWM Controller
- Parameters:
[in] pwm,: channel to use (0-3) [in] duty,: high time in percantage (0-100)
