Tools and Utilities - Windows Embedded Compact
All of this software is available for free if not stated differently.
The table entries are encoded as follows:
f = full support
p = partial support
- = no support
N.A. = not available
Windows CE Tools
Tool | Description | Apalis iMX6 | Apalis T30 | Colibri T30 | Colibri T20 | Colibri iMX6 | Colibri VFxx | PXA3xx | PXA 270 |
AC97Tweak | Configures some special audio codec features which are not accessible through the common wave API. Audio input settings: source left/right, micboost, gain left/right, DC filter, High pass, mute. Audio output settings: gain left/right, bass, treble, de-emphasis, headphone driver, mute. Audio test features | - | p | p | p | - | - | f | f |
ColibriCustomize | Customization possibility of the Colibri Win CE image. Automatically configures the registry for your own settings (Using .reg file). | - | - | - | - | - | - | f | f |
DbgMsgLogger | Displays all debug messages from RAM buffer. | - | f | f | f | - | - | f | f |
ColibriMonitor | Shows the usage of the CPU/RAM, processes/threads running, thread priority and has setting functionalities. | f | f | f | f | f | f | f | f |
ColibriTweak | Adjusts system parameters like display settings, access registers, etc. of the Colibri module. | - | p | p | p | - | - | f | f |
ConfigBlockEditor | Edit settings stored in the config block. | f | f | f | f | f | f | f | f |
GPIOConfig | Provides an interactive interface to the versatile GPIOs of the Colibri modules. | - | f | f | f | - | p | f | f |
ImageViewer (a) | Provides basic functionality to display a single image or a slideshow. | p | p | p | f | p | p | f | f |
Launcher (a) | Automatically runs any .exe or .Ink file found in an AutoRun folder or copies files in a folder AutoCopy folder on each storage medium. | f | f | f | f | f | f | f | f |
RegAccessTool | Read from and Write to physical addresses (registers, etc.) in 8bit/16bit/32bit format (Formerly part of Colibri Tweak tool). | - | f | f | f | - | f | p | p |
RTCSync (a) | Synchronizes the system time with the RTC chip on I2C. | f | f | f | f | f | f | f | f |
SplashScreen | Changes the picture which you can see while WinCE is booting. Now integrated in to the Update Tool. | - | f | f | f | - | - | f | f |
TouchTweak | Adjusts the touch screen driver to your touch screen if required. | - | - | - | - | - | - | f | f |
UpdateTool (a) | Updates the WinCE Image and bootloader, warmboot or coldboot, etc, part of the standard image. | - | p | p | p | - | - | f | f |
VideoPlayer (a) | included in standard WinCE image. | - | f | f | f | - | - | - | - |
NOTE:
- (a) Already included in the image.
See here for more information on our Windows CE features.
PC Tools
Tool | Description | Price (Support Hours) |
Colibri Loader | Loads bootloader over JTAG (only for Colibri PXAxxx modules), load Images over Ethernet | Free |
RemoteDisplay | Controls the Colibri module by a desktop PC (keyboard, mouse, display, file transfer) using a connection through ActiveSync (USB) or Ethernet. | Free |
CreateTBin | This Windows program converts an OS binary file into a format that works with the Toradex Tool Chain. | Free |
Splash Screen Customizer | Creates a customized splashscreen which can be shown while Windows CE is booting. | 4 |
Win CE Image Compressor | Reduces the size of the Windows CE Image to about 50%. This leaves more flash space for user applications or the flash file system. | 5 |
