Watchdog Software Library API
This article describes the Watchdog software library API and provides a functional overview
Defines | |
| #define | WATCHDOG_VER_MAJ 1 |
| Major Library Version. | |
| #define | WATCHDOG_VER_MIN 0 |
| Library Subversion. | |
| #define | WATCHDOG_VER_BUILD 0 |
| Library Build. | |
Functions | |
| void | WatchdogGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
| BOOL | WatchdogInit () |
| BOOL | WatchdogDeinit () |
| BOOL | WatchdogRetrigger (DWORD Timeout_ms) |
Detailed Description
WatchDog Support Library.
- Copyright:
- Copyright (c) 2012 Toradex AG [Software License Agreement]
- Version:
- $Rev$
- Date:
- $Date$
- Target Platforms:
- Colibri PXA320, Windows CE 6.0
- Caveats:
- The watchdog does not work on PXA270 due to bug in the PXA270 CPU.
Define Documentation
| #define WATCHDOG_VER_BUILD 0 |
Library Build.
| #define WATCHDOG_VER_MAJ 1 |
| #define WATCHDOG_VER_MIN 0 |
Library Subversion.
Function Documentation
| BOOL WatchdogDeinit | ( | ) |
Deactivates watchdog This is not possible, therefore the function always returns FALSE
- Return values:
TRUE success FALSE error
| void WatchdogGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
returns the version of this library
- Parameters:
[out] pVerMaj Main Version of this library [out] pVerMin Subversion of this library [out] pBuild Build Number of this library
| BOOL WatchdogInit | ( | ) |
Activates the watchdog, and sets the Watchdog timer to the maximum timeout: 2^32 ticks / 3.125MHz = 1'374sec = 23min.
- Return values:
| BOOL WatchdogRetrigger | ( | DWORD | Timeout_ms | ) |
Retriggers Watchdog
- Parameters:
[in] Timeout_ms A hardware reset will be done if the Watchdog is not retriggered within this time [ms]
valid range: 1...1'374'389
- Return values:
