WinCE Fast Boot
We provide demo fast boot image in a download below. If you want you can also use work-space to build your own custom image.
Demo image download
Windows Embedded Compact 7.0
OS Image
Please note there are quite some limitation in our pre-built image.
Building your own image
You can download the work-space provided here
Workspace
Binary BSP
When building image please note a file called PBWORKSPACEROOT%\ToradexFiles\multibin.txt. Inside you can see the list of files that are going to get manually removed from image even if you add them to bib file. If you want any of this files included you should also delete them from this file.
Tezi compatible images
Workspace
