Windows CE Library - I2C Library - (I2CLib)
Description
This library manages communications via the I2C interfaces.
Current Version
V4.4
Application Notes
This library supports 100KBPS and 400KBPS.
This library uses a mutex called 'I2C' to control against simultaneous access.
Currently, this library supports only one I2C instance at a time.
Revision History
| Date | Rev | Change Notes |
| 29/06/2015 | V4.4 | Add support for non-DWORD-aligned receive buffer (Tegra only) Prevent possible application hang (add timeout) when i2c signals were floating low. |
| 30/10/2014 | V4.3 | Add support for all i2c channels on T20 and T30. |
| 09/07/2014 | V4.2 | Fix i2c protocol in I2CBurstRead() for T20 and T30: Do not send STOP condition after transmitting the offset value. |
| 15/04/2014 | V4.1.1 | Internally mask slave address for the range 0..127 |
| 11/03/2014 | V4.1 | Fixed missing deinit of a variable for the T20/T30 modules in the I2CDeInit() function Added more error checks |
