Windows CE Library - Image Overlay Library - (OverlayLib)
Description
This library manages RGB and YUV overlays for use with video and images on PXAxxx based modules.
Current Version
V0.2.1
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 23/09/2013 | V0.2.1 | Change default SDK to Colibri600 |
