Windows CE Library - Peripheral Clocks Library (CLKLib)
Description
This library manages peripheral clock settings.
Current Version
V3.3
Application Notes
On PXAxxx processors, each clock can simply be enabled or disabled.
On Txx processors, the library can select the correct clock source and divisor to either provide the closest frequency to that specified or to select the lowest power-consumption oscillator giving a frequency within a specified range.
CLKLib also contains a function to provide for blocking delays with a 1uS resolution.
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 11/03/2014 | V3.3 | Prevent using non-constant clock sources PLLC and PLLM in function ClkLibSetClockFrequency() |
| 23/09/2013 | V3.2 | Change default SDK to Colibri600 / Extend T30 support |
