Windows CE Library - Pulse Width Modulation Library (PWMlib)
Description
This library manages the PWM interfaces.
Current Version
V2.1.2
Application Notes
The PWMLib supports up to 4 PWM signals
The PWM duty cycle can be set as a percentage or, with more precision, in clock units.
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 24/06/2013 | V2.1.2 | Added parameter type definition to DeInitPWM() |
| 17/06/2013 | V2.1.1 | Updated to work with Apalis T30 |
