Windows CE Library - System Clocks Library (FREQLib)
Description​
This library manages system clock settings.
Current Version​
V2.3
Application Notes​
FREQLib allows for the setting and querying of various clock speeds on PXA and Tegra.
FREQLib also allows for the core voltage to be set on PXA270.
Library API​
Other Resources​
Windows CE Libraries Overview
Revision History​
DateRevChange Notes
29/06/2015V2.3Internal modification to evaluate an error condition.
09/07/2014V2.2Added function TegFrq_Boost()
This function allows to dynamically set the minimum required system frequencies
11/03/2014V2.1Fixed calculation of system frequencies (affected Colibri PXA modules only)
23/09/2013V2.0.1Change default SDK to Colibri600
12/08/2013V2.0Added functionality to get and set system clocks for Tegra processors
