Windows CE Library - Update Library (UpdateLib)
Description​
This library manages the programming of Image/Bootloader/Registry in on-board flash.
Current Version​
V1.10
Application Notes​
UpdateLib provides full support for Backup and Update on Colibri PXAxxx modules.
UpdateLib currently only provides Update support on Tegra modules.
Library API​
Other Resources​
Windows CE Libraries Overview
Update Tool
Production Programming (Tegra Modules)
Revision History​
DateRevChange Notes
29/06/2015V1.10Adjust the default file name when backing up
When flashing a splash screen, configure config block settings "oep" and "dispondelay"
Implement workaround for Kernel bug in Colibri PXAxxx BSP V4.4
30/10/2014V1.8Support new Spansion Flash
Support 1:1 Backup/Restore for Bootloader and image on Tegra modules
15/04/2014V1.7Implement Bootloader Update for T30
11/03/2014V1.5Fixes in clear registry part
Improved error reporting
Modified UDLReboot to prevent system freezes when shutting down the system.
23/09/2013V1.4Change default SDK to Colibri600 / Added support for Wiping the FlashDisk
12/08/2013V1.3.3Fixed issue with ClearRegistry() on Tegra on CE6/7
