eCos® RTOS on the Cortex M4 of a Colibri VF61
eCos
The Colibri VF61 uses a NXP/Freescale Vybrid™ SoC which consists of two heterogeneous CPU cores: An ARM Cortex™ A5 and a Cortex™ M4. Linux makes use of the Cortex™ A5 CPU only. The Cortex™ M4 is a micro-controller core suited for application specific Firmwares/RTOS. Antmicro, a partner of Toradex, ported eCos® RTOS for the Cortex™ M4 CPU. Starting with the V2.1 Beta 3 image for Colibri VF61 our image delivers all tools necessary to load a Firmware into the second CPU Core. This Article shows How To get started building and loading an eCos Firmware.
Development Environment
In order to build eCos, a Cygwin or Linux based development environment is required. We distribute a pre-configured virtual machine for Linux to get you started.
Using your Linux Distribution
As a development environment virtually any Linux distribution should work. We usually test the documented commands on Ubuntu 12.04 LTS release. Since the cross compiler tool chain is distributed in 32-Bit variant, 32-Bit run-time libraries are required even on 64-bit variants:
sudo apt-get install ia32-libs
Using the pre-built Virtual Machine
The Ubuntu 12.04 LTS based virtual machine is available in the open virtualisation format (OVF). You can download the disk image and the descriptor file from our website:
  • http://developer.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/VM/Colibri-VF61-VB-disk1.vmdk (disk image, about 1.6GB)
  • http://developer.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/VM/Colibri-VF61-VB.ovf (Virtual Machine descriptor file, ~14KB)
Nearly any recent visualization Software supports the OVF format. VirtualBox is a free Desktop visualization Software we can recommend.
You can Login using the following credentials: - Username: ant - Password: antmicro
This user is in the sudoers group, you can gain root access using "sudo su" and the same password.
Get the eCos® Source Code
eCos 3.0 for Colibri VF61 is available in source form through our Git Repository.
$ git clone git://git.toradex.com/ecos-toradex.git ecos-colibri-vf61/
When using the virtual machine, eCos for Colibri VF61 is already available (see the "ecos-from-scratch" folder). However, this source release might be out of date. To get the latest version, you can update the repository using git pull.
$ cd ~/ecos-from-scratch/ecos-colibri-vf61/
$ git pull
Note: We do not distribute binary releases for eCos Kernel since applications need to be linked against the eCos Kernel. Once the tool chain for eCos is setup, it can be used for eCos application development as well.
Get the documentation
Our partner Antmicro wrote a complete Manual which is part of the eCos release (see "doc" folder). You can use the make command to build the documentation in different formats. In the Virtual Machine, you can browse a HTML version of the documentation by opening Firefox.
Alternatively, you can download the documentation in PDF format from our doc server.
Build the Documentation
To update the documentation, use make:
$ cd doc/
$ make html
Note: Depending on the format and your Linux distribution different packages might be necessary (e.g. python-sphinx, texlive-latex-base and texlive-latex-extra).
Build an eCos® Firmware
For this step, please check the mentioned eCos Manual above.
Run an eCos® Firmware
There are several methods how to start eCos on the Cortex M4, we again refer to the mentioned eCos Manual above.
However, from within Linux you can run the Hello World example in two easy steps:
$ modprobe mcc
$ mqxboot hello.bin 0x3f000400 0x1f000411
On the UART_B you should get the following string output (at a Baudrate of 115200):
Hello, eCos world!
Note: You can not run the firmware a second time since the Cortex M4 firmware is already running.
Newer Compiler: If you are using newer Linaro compilers, you need to extend LDFLAGS -Wl,--build-id=none to avoid the errors like:
ld: error: no memory region specified for loadable section `.note.gnu.build-id'
Webinar: Heterogeneous Multi-core Processing
