Flashing Linux NAND Preparation
This prepares a SD card or USB flash drive for later use on the carrier board with the module which is to be flashed.
  1. Download the binary image and extract it with root permissions. The binary image files are named as follows:
    • Starting with version 2.7.2
      <module-type>_<image-name>_<version>.tar.bz2 where <module_type> is one of Apalis-iMX6, Apalis-T30, Apalis-TK1, Colibri-iMX6, Colibri-iMX7, Colibri-T20, Colibri-T30, or Colibri-VF and is one of LXDE-Image or Console-Image.
    • Older versions
      <module_type>_LinuxImageVx.yz.tar.bz2 where <module_type> is one of Apalis_iMX6, Apalis_T30, Apalis_TK1, Colibri_iMX6, Colibri_iMX7, Colibri_T20, Colibri_T30 or Colibri_VF.
    Binary images of the Toradex BSPs can be downloaded from http://developer.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/Images/.
  2. Use any FAT formatted SD/uSD card or USB flash drive with enough free space (1GB or more recommended).
    Note: U-Boot expects a partition table (MBR) on the SD card or USB flash drive and the FAT partition to be the first partition!
  3. Find the mount point of your SD/uSD card or USB flash drive by e.g. using df or lsblk:
    [user@host ~]$ df
    Filesystem              1K-blocks      Used Available Use% Mounted on
    /dev/mmcblk0p1            7582228   2808272   4773956  38% /media/KERNEL
    [user@host ~]$ lsblk
    NAME                         MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
    mmcblk0                      179:0    0   7.3G  0 disk
    └─mmcblk0p1                  179:1    0   7.3G  0 part  /media/KERNEL
  4. Run the update.sh script with the -o argument pointing to the mount point of the SD card or USB flash drive. For example assuming the SD card is mounted at /media/KERNEL:
    ./update.sh -o /media/KERNEL/
    At this point the SD/uSD card or USB flash drive should contain U-Boot, optionally the Linux kernel, the flashing scripts and the ext3 (for eMMC modules) resp. UBI (for NAND modules) root file system images.
